port and polish scion tc head
^^ And to not hit the water jackets..
Originally Posted by hPower
Originally Posted by jwaggz82
ha - are you very experienced or are you unexperienced and leading people into believing this can be done by the unexperienced?
PnP should be done via an experienced person that has been in the scene for a while. There are tricks and tips that an experienced person will know. Don't think about doing this yourself guys (unless you know what you are doing).
there is alot good info on the web if you take your time to read carefully about the process and using the tools to do it. if you do decide to make this attempt please for your own good find a practice head. this does not have to be true or a perfect cast. you can do it with a cracked head if all you are doing is practicing. this will help you with learning how each stone and paper work and also what you should expect to take off.
I encourage any one who wants a p&p head to go the junk yard, find a used aluminum head for cheap and attempt to do it. if you think you did a moderate job, try agian with another junk head. if you still have no confidance leave it to the pro's.
there really isn't that much engineering into it. the principal is to smooth over any rough surface's and get rid of obstructions to the flow of air. you should not try to go with a big bore, or just make the chambers larger. these heads are designed pretty well and the stock chamber size is really great. all you want to do is smooth over obsructions, and get air to flow through.
PTUNING
12-11-2014 08:09 PM
ScionLife Editor
12-06-2014 11:58 PM
PTUNING
12-06-2014 03:58 PM
