ported throttle bodies.
Old 06-20-2009 | 04:55 AM
elcapetan's Avatar
Originally Posted by BlackKnight
Originally Posted by Iowa_TC1
Originally Posted by elcapetan
lol ok.the picture would be much better if it had been taken looking down at both of them so you get a better idea of the difference.
You guys should also look into the throttle tune from World motorsports, It gets rid of the electronic delay and makes the throttle a lot more responsive, like a cable.
Everyone thinks there is a electronic delay even if there is its less than a second, the problem is the engine response which can easily be fixed with one step colder plugs, lighter flywheel, and tuning.
You can use one step colder plugs on a stock motor?
Old 06-20-2009 | 09:28 AM
BlackKnight's Avatar
Music City Scions
I thought the delay wasn't that much either until I put the throttle tune on, it made me a believer, this was after I had my car tuned to.
I am interested in a port throttle body to, has anyone on here tried gude's?
The delay isn't in the throttle body itself the delay is the OEM tune the computer is setup for emissions and not performance.
Old 06-20-2009 | 10:08 AM
A-snell's Avatar
so, the engine s in the tC and the xB2 are the same motor. so why does the tC have 3 more HP than the xB2 from factory? bigger cams? tuning? TB?
Old 06-21-2009 | 11:26 PM
speedy000's Avatar
wouldnt it have something to do with the transmission and axles....the tc doesnt lose as much power from the engine to the wheels...but im just guessing.
Old 06-22-2009 | 10:24 PM
A-snell's Avatar
^ well, I know speed has a lot to do with aerodynamics, but WHP doesn't. I believe they share the same drive train, but I could be wrong.
Old 06-23-2009 | 12:28 AM
speedy000's Avatar
^ it could be the intake isnt the stock intake different from the tc!?
Old 06-23-2009 | 07:38 AM
Music City Scions
I had a CAI, Exhaust, and Header my car was acting like it wanted to die when I would approach a stop and stepped on the clutch (engine in neutral) the rpms would drop down below the point it normally idles (down to 500 rpms) then come back around 600 rpms for idle. After I changed the OEM plugs to NGK Iridium one step colder it stopped doing that and would idle down better, idle better, and go through rpms smoother.
Old 06-23-2009 | 04:12 PM
speedy000's Avatar
what part number r u guys using for the ngk plugs every auto place i go to say they dont make ngk for the tc!
Old 06-27-2009 | 02:34 AM
gingles's Avatar
ngk spark plug for stock is.....bkr6eix
Old 06-27-2009 | 04:20 AM
Music City Scions
With who's car? Both tc's I have owned came with Denso IK22's or 20's I don't remember the exact number.
Old 01-15-2010 | 08:48 AM
KillaKeola's Avatar
I will keep everyone updated i'm looking at a rx-8 tb sometime this week. If it looks like it will fit ill try it out.
Have you looked to see if the rx8 TB fits the Tc? Wheres the update?
Old 01-15-2010 | 09:21 AM
elcapetan's Avatar
Have not been about to do that swap yet. but... the pic that was posted on an Rx-8 TB looks very similar to ours. We won't know for certain until someone can do the swap. I will try to get a hold of my friend asap.
Old 01-15-2010 | 09:54 AM
OuterHeaven's Avatar
If I remember correctly, there was someone on e-bay selling a RX8 TB adaptor kit. I think the mounting points are different and would require an adaptor of some kind but the kit claimed that the RX8 TB had the exact same connector for the ECU and could just plug right in with no tuning. I am sure some tuning would be required when changing the TB but since an adaptor is required I would rather install this onto an aftermarket intake manifold.
Old 01-15-2010 | 10:14 AM
elcapetan's Avatar
look at pics earlier in this thread the TB electronic adapter to ECU is same on the RX-8 as our car.
Blunderbuss
10-08-2015 05:56 PM
MeDizzy
10-08-2015 04:31 PM
Spitfire23
Scion tC 1G ICE & Interior
09-08-2015 04:31 AM
RokGoblin
08-11-2015 06:24 PM
