Power Steering Delete/Removal/Tuck
I have seen a few tCs with deleted or tucked power steering.
Can someone provide a list of things/parts that are necessary to delete the power steering?
Also, If I just wanted to hide the resevoir behind the engine rigth near the power steering pump is this possible? Would it be ok to have the resevoir that low?? Any tips/hints/help is welcome. Thanks.
If you eliminate the power steering its going to be much harder to turn than a car that was designed without power steering (like your CRX). The gear ratios in the rack on a car with power steering are lower than one without so you don't have to turn the wheel as much to go to lock.
Do you have any pic of your setup? why would I have to buy longer hoses? Im going to hook it up right where the pump is shouldnt they be shorter? Or does it have to be at the same height in the bay as it was before?
Greg S
07-21-2016 07:28 PM
Brimmer555
05-31-2015 02:31 AM
Zipo
04-13-2015 03:31 PM
