Problem with steering
Not sure if it should go here it not so please move if need be thanks.
So my problem is when I'm driving I can feel the whole has a shake to it kinda like a flat tire shake or going over rumble strips in the road. I can feel it in the pedal and the steering wheel and floor.
Now I am sitti g on 19's with Rokkor tuning coils and dezod adjustable end links for the sway bar.
What could be the problem?
Has it snowed there recently? And while in the snow, have you been e-brake sliding? The built up snow will make it feel like your driving on rumble strips. If so, let it sit and melt and the problem will go away. Otherwise, if it does it constantly and doesn't stop at any speed or anything, then you probably have a problem. Take the dealer for a ride and they'll know what's up.
It did snow but it's all gone already and I don't drive it in the snow at all haven't in 5 years. And I have no more warranty left so no more dealer lol.
I feel it at speeds from about 25 all the way up doesn't stop gets worse at 70 turns into a really bad vibration
Your tires are cupped either from defect (if you just got new tires), uneven wear due to toe/camber from alignment. Rebalancing them can slightly help with the vibration, but it will not fix the problem. I used to have cupped tires on my old wheels and had the same problems you are describing, also are your tires really loud when driving?
CombatmedicR56
11-12-2020 01:53 AM
CapnChunk
04-13-2015 04:06 PM
Beesh
01-09-2015 06:30 PM
bobbyboshay
01-11-2004 12:05 AM
