Prototype tC - Weapon*R Sheet Metal Intake Manifold.
Old 08-02-2008, 05:45 PM
  #81
BZinn1's Avatar
I wnet and looked with my mirrors this morning and there is one bolt that looks very near impossible to get at.......all the rest with a good set of sockets,extensions,woblers,and wrenches are all accessable.
Looks like once the TB is off you have a nearly clear path to everything except one bolt.....my guess is since it is plastic it is not gonna be on there so tight you would need a long wrench to get it off but you never know.....
This looks installable ........hope they get good numbers on it........as I would buy it just to be rid of the stock one and free up a bit more power.
BZinn1 is offline
Old 08-02-2008, 07:05 PM
  #82
unxpectederror's Avatar
Originally Posted by jjos1
Wow cams then this :D
cams, cracked ecu now intake manifold all in the past month or so
yup life is getting better for us tC owners...
unxpectederror is offline
Old 08-03-2008, 04:40 PM
  #83
e246's Avatar
Get good gains and a decent price and ill get one.. Keep us informed..
e246 is offline
Old 08-03-2008, 10:16 PM
  #84
mengsta's Avatar
Well If the IM doesnt change the smog numbers then there is no need to switch out the part when the time comes? I doubt most of those smog technicians will notice the IM in the visual inspection. Just like the intake; i dont see how the IM would have any effect on the Carbons in the air. So i guess to finally end my jabber, the IM would not be required to be replaced when smog time comes? lol Thanks, Peace
mengsta is offline
Old 08-04-2008, 05:17 AM
  #85
highvoltage1's Avatar
watching
highvoltage1 is offline
Old 08-04-2008, 09:23 PM
  #86
ProjectPerformanceRacing's Avatar
i just took off my head for a port job, i took off the intake manifold. Its a pain but not impossible, i did release the motor mount on the passenger side to make it easier. what about price? i def want one
ProjectPerformanceRacing is offline
Old 08-08-2008, 01:14 AM
  #87
Mecanica_Pito's Avatar
Originally Posted by equinox2355
You dont have to do any of that, just take out the wipers, and the cowl and those parts, and you will have a clear shot, i looked at the info and you dont take the mounts out to get to any of the bolts (and thats straight from toyota's mouth) you could do it that way and take out the mounts, but thats way more work than needed. If you are cool with any of the techs at the dealer(s) near you, get a copy of the info on how to take out the manifold (that way you dont do more work than needed)
Removing the cowl and wipers won't help much to remove the Intake Manifold because some screws are hard to reach and the cowl is in the oposite side of the IM. It migth help a little bit but not enough to justify the effort of removing the hole cowl assembly.
You need to lift the car in order to loosen some screws and also some wiring holders that are attached to the IM from below. I have removed it and the screws can be removed with the engine in but the IM WILL NOT FIT in the space available. You need to loose the front and rear motor mounts to tilt the engine and make space to remove it.
I do think that the new IM will be easier to install than the OEM one.
Pito
Mecanica_Pito is offline
Old 08-08-2008, 03:00 AM
  #88
cee_dub2003's Avatar
The Manifold is still in prototype stages. We will update as soon as we can!!!!!
cee_dub2003 is offline
Old 08-11-2008, 06:32 PM
  #89
jimmyjun's Avatar
updates please!!!! very interested
jimmyjun is offline
Old 08-11-2008, 06:39 PM
  #90
equinox2355's Avatar
Pito
I am not here to dispute if it would help to remove the cowl or not. I am here to say what TOYOTA says to do to remove the intake manifold. End of discussion.
equinox2355 is offline
Old 08-11-2008, 06:45 PM
  #91
aen
aen's Avatar
why are you so defensive?
you said we did per toyotas instructions
pito said we didnt' per experiance's instructions.
relax he never said anything that should have offended you
aen is offline
Old 08-11-2008, 08:43 PM
  #92
jjos1's Avatar
Any chance of getting a big bore throttle body to go with it
jjos1 is offline
Old 08-12-2008, 12:10 AM
  #93
I AM here to help people when they have questions so they can ignore people that have only read the PDF that TOYOTA made!
Pito
Old 08-12-2008, 01:25 AM
  #94
weeloTC's Avatar
cant wait to see some numbers!!!!!
weeloTC is offline
Old 08-12-2008, 02:02 AM
  #95
jroc's Avatar
^^^x2
jroc is offline
Old 08-12-2008, 02:06 AM
  #96
Pito
Pito FTMFW.
You guys are doing awesoem things out there in PR. Keep it up.
Old 08-12-2008, 02:21 AM
  #97
Socal_Shara's Avatar
watching
Socal_Shara is offline
Old 08-13-2008, 04:09 AM
  #98
m6ar2cel6oTC's Avatar
Pito
where can i gget this PDF? just curiousity i just wanna see it so if i ever have a question i can just look it up? anyone have one to send it to me or know where to get one online? email it to me at m.cederna@gmail.com or contact me thanks.
m6ar2cel6oTC is offline
Old 08-13-2008, 12:33 PM
  #99
SilverCFtC's Avatar
In like flint watching. I think 2009 is going to be a very expensive year :D
Looks like I'm gonna need a new job.
-Sean
SilverCFtC is offline
Old 08-14-2008, 07:07 AM
  #100
peety's Avatar
anyone know how much hp this might add, because if i get this ( which i might ) im going to port match the head. so i think that should be a killer combo, because i also have MMW 4-2-1 header
peety is offline
Quick Reply: Prototype tC - Weapon*R Sheet Metal Intake Manifold.
