Quaife LSD
Originally Posted by Petem
LSD is a drug.... primarilly used in the 60's...
just kidding.. however.. LSD IS a drug.. but the LSD we speak of here is a Limited Slip Differential.. it applies power to both front tires instead of just one...
Originally Posted by English
Wrong!
An LSD still supplies more power to the wheel with the most slip, but still transfers a percentage of that power to the other wheel.
NO LSD has 100% lockup, usually it's around 30% or so (not sure though) but on a 30% lsd, the wheel with the least traction (least friction) has 70% of the power and the one with the most friction has 30%.
Only vehicles with very sophisticated 4 wheel drive systems have what you're talking about, and that's because they apply the brakes to the wheels which are slipping, forcing the other wheel to get the power.
http://auto.howstuffworks.com/differential10.htm
I've installed a quaife LSD on my friend's '03 SRT-4 (before they came standard). I know for a fact that it transfers most of the available power to the wheel that does have traction. I know that other types of differentials work on different principles, but in the case of quaife (which this thread is about), the power goes to the wheel that is hooking up to the ground.Thanks oldman, I know my explanation could have been worded much better
[quote="oldman"]
um this type of AntiSlipRegulator is not a LSDifferntial and serves only to confuse the post not prove you are correct.
This part of my post was obviously not talking about LSDs, thanks.
Oldman, you must admit LSDs do apply power to both tires instead of just one (open differential) so BreakTheStatic would be wrong to say LSDs do the opposite of applying power to both tires, which would be apply power to only 1 wheel. BTW torque steer would be around corners not on launches, unless you have the wheel turned on the launch, which technically would be around a "turn"
And 33% locking is a 2:1 Ratio!
Also, manual lockers, air lockers, and cable operated lockers are not LSDs and serves to confuse the post not prove you are correct!
Thank you for correcting me on the parts I was wrong about
Actually, LSDs do the opposite. They apply more power to the one wheel that IS getting traction, not both. That way the car keeps the power on the ground on launches (w/ torque steer) and around turns
Torque steer isn't only felt on turns. Even during straight acceleration, one wheel frequently gains more traction than the other and causes the car to pull to one side. And here "Actually, LSDs do the opposite. They apply more power to the one wheel that IS getting traction, not both. " Keyword being MORE. I may have been slightly tired when I posted it, but what I was saying was not that LSDs ONLY powered one wheel, but that it provides a torque bias to the wheel which currently has traction.
Originally Posted by ChiTowntC
is the front wheel drive the reason why when i hit the gas the steering jerks around? the fact that the power is going to one front wheel so it wants to pull to the side?
Your post also insisted that LSD apply more power or torque to the wheel with the most slip, see here:” he wheel with the least traction (least friction) has 70% of the power and the one with the most friction has 30%” Which is also WRONG.
Also a word of caution from a LSD FWD driver. If you get on boost in a turn the car will tend to understeer, (travel in a straight line), this is especially true in limited traction conditions. This is because neither tire has a static coefficient of friction with the pavement hence no steering is possible. Don’t get silly as kids on the street corner can die. Once you make the step up to turbo and LSD, a whole lot of respect is needed.
I'm down for a phantom grip group buy, BTW how well does the phantom grip perform, i've seen it before but have never seen a review of it yet or the phantom grip in action. I was shopping for LSD"s and Phantom Grip looked to be the cheapest but i've always questioned it's performance coming from an a Torsen AWD car.
