question regarding my clutch
i have a 06 tc with about 45k miles on it and just starting to noticed when i push in my clutch makes a tiny little sqeaking noise sounds like needs some lubercation or something.....
its not loud but it may be common but not sure
yep it is comman......the pivit point inside where the arm is attached is low on grease,pain to get to,remove the rubber boot on the case and if you can get a can of spray white grease and a tube you can spray it in there behind the arm,just dont lose the tube inside.
Hey i just noticed the same noise yesterday and now today when I got to work. It sounds like a high pitch squeaking coming from under the hood when i press the clutch in and out in neutral, but it does not do it all the time. its an 09 tc with only 17200...
thanks
Chris
thanks
Chris
