Randomly re-occuring low idle/stall problem (with video)
Old 04-29-2012 | 04:13 AM
HKSpeed's Avatar
Default Randomly re-occuring low idle/stall problem (with video)
I finally made a video of my tC's re-occurring low idle/stalling problem. Today I unplugged the battery to install a steering wheel. The low idle (see video below) occurred after I reconnected the battery and started the car. This problem happens every now and then, but goes away if I don't drive the car for several hours. I can make the problem appear if I cold start my car (hasn't been driven for several hours), then turn off the engine before it warms up. If it restart it within a few minutes, the low idle problem occurs. This problem happens 2-3 times a year, but goes away the next day. It started happening when the car had about 30K miles. Your thoughts? I searched, but no one seems to have found a definite solution.
Video I made today of the problem. The engine dies on its own near the end of the video.
About my car:
Purchased new in June 2005
74K miles
manual trans
Engine mods: K&N drop-in/panel filter, Megan S pipe, HKS axle-back muffler
No CEL
Old 04-29-2012 | 03:48 PM
Supra12big's Avatar
Have you tried cleaning your maf sensor? Also try cleaning the throttle body as well. Usually when you disconnect the battery on the tc, the ecu has to readjust so it will idle that low, ever since I cleaned my throttle body, every time I re set the ecu, it will go right back to where it was...
Cliff's
Clean MAF
Clean Throttle Body
Old 05-02-2012 | 04:18 AM
L33T_TC's Avatar
This happened to me the other day, took it to Toyota and they fixed it for free. The air intake wasn't completely sealed making the computer do that to it.
Sooby
Scion tC 1G Wheel & Tire
11
04-09-2020 12:51 AM
2CTC
09-12-2015 12:33 PM
carid
01-22-2015 01:49 PM
cid_mcdp
01-05-2015 03:45 PM
fluxingnation
12-26-2014 05:28 PM
