Resetting ECU?
Take off the negative battery terminal, step on the brakes (drains the power quicker, brake lots use a lot of juice), reconnect battery, start the car and let it idle for about 10-15 min. I could be wrong about having to press the brakes but it worked for me lol eithr press the brake or just leave the battery disconnected for about 15-20min.
You're retarded and should be banned for a few days for telling someone to do that.
Go find something productive to do.
Scionlife Rules For All Forums
To post here, you agreed to follow these rules...
1. I will keep my posts relevant and helpful.• Be helpful and do no harm!
• Post that have veered off topic or bashing WILL be locked, split or deleted.
• Do not multipost the same subject on different areas. This is considered Spamming and will be deleted.
• Allowed multipost are Large Events (I.e. HIN etc), threads will be Locked and Linked to the Region or Club.
• Any personal attack on a member will not be tolerated.
OP: Disconnect the -neg battery terminal for 10-15min then reconnect and let the car idle with AC, radio and headlights off for 15min.
Shame on you Led-Maniac!!
anyways, the best way to reset is to disconnect the negative battery terminal for atleast 15mins. Then when you reconnect, start the car make sure you let it idle for 15mins also.. meanwhile you can reset the windows and moonroof.
yeah you can pull the negative battery cable or like was stated above you can pull a fuse or maybe two i can't remember ever so i never do it but do make sure you just let the car idle and don't rev it or anything
I know that some cars when you install a new part, a reset of the ECU is required to get the "full effect" of any changes/mods made to the engine/intake. I was wondering if this was also true for the tC? I know that battery terminals can be disconnected for about 15 minutes or so, but that also removes all electronic settings- windows, radio presets, radio welcome message, etc.
I'm sorry I meant both cables of the battery, thus having no power hooked up to the system....[take off both negative and positive] So once the battery is full disconnected, you can remove it from the car, if you touch both cables it will quickly drain all voltage and reset the ecu [some is still retained by capacitors throughout the system]. We [ASE techs] do this at my shop all the time to rule out any erroneous SRS or check engine lights. I didn't mean to confuse anyone...I should have mentioned both terminals, i.e. disconnect the battery. There is NO harm =]
Klashan
09-24-2015 01:39 PM
