Which resonator to get?
Right now I am running Megan-Racing Headers, stock-mid pipe and s-pipe, and HKS Hi-Power axle back.
By now you probably guessed my problem. Rasp.
Immedietaly someone is going to say loose the headers. Well, i don't want to do that, what would be the point of getting them in the first place?
So I'm looking for a the cheapest way to reduce rasp and maybe even a little bit of loudness. I was thinking of buying an s-pipe + midpipe, and then welding a resonator and a high flow cat. But my question is what brand and how much? Also, is there any aftermarket midpipes that come with a resonator or a catalytic converter?
___________________
All right, all of the above was basically answered, so what/which brand/model resonator should i get. Someone mentioned this one on a different thread.
http://moesperformance.com/index.php...7476ae637d3015
Any good?
But i think it may be too short.
Thanks in advance SL guys.
___________________
Any good?
Megan makes a mid pipe. From what I hear the megan full exhaust isn't raspy I haven't heard one yet so I dont know the truth to this. I know tho you need resinators to help reduce the rasp... But yet again I dont know to much about this car and only go by what I want and like... Hope it helps out a little bit
get an s-pipe and keep the stock mid-pipe and weld the resonators to it. getting a new midpipe(brand name) and cutting it to weld a resonator is a waste when you can just go custom with less of the cost but then cops will be all over you because of how loud it is going to be.
reduce rasp..yes, lower the loudness..it should but not like alot. there's alot of people who have the midpipe as well and it loud enough that a cop doesn't even need to think twice about pulling you over.
the stock pipe is 2.25, go for one that is 16" and give that a try to reduce most of the rasp depending on how much you have. if you have alot then 2 resonators will do the trick but if you have very little then 1 will be fine. the s-pipe will barely make it louder because that is where most of the restricted air gets jammed. you won't notice it much from the outside but more from the inside.
All right for now, i'm just going for eliminating the rasp, so i think i'll just stick with the resonator...what about the catalytic converter? is that need it/worth it if don't have a CEL with my headers?
Also, when cutting my stock midpipe, where should i cut it to weld in the resonator, after the o2 sensor right?
i don't remember if the mid-pipe even has an o2 sensor which i doubt it does but whoever is welding it for you will know exactly where to put it. as for putting another CAT just forget about it, you lost the one from the headers and that is the main one that counts and can't be replaced unless you go back to stock headers which you don't want to but it's not needed which is why you feel more of a push when you step on it because nothing is holding back that exhaust air.
riccochetrabbit
19
08-30-2005 07:03 AM
