RPM's bouncing up and down ?
Yes you can hear it and feel it. Something like this problem the dealer will look right at all the mods you did and tell you that is the problem. So the dealer ship is out of the question for this kind of problem.
ive had my tc for like 6 months so far and this problem just started happening...like ^^^ my rpms drop all the way down to the 5's and go back up to the mid 1k...the problem im having is that it does it a few times until i get off the clutch again. i live in cali so it does it whether its hot or cold...and it happens when im in traffic or cruisin at 70...soooo idk wtf is up....
sorry just need confirmation
1. so 05-06 engines have a rev limiter that makes the needle bounce off the red line. 07-08 have a fuel cut off valve that cuts the fuel to the engine when exceeding red line, but does not have the need bounce
2. it is normal to have your rpms go up when you put it in neutral and you are coasting on the freeway
mine does the same thing... ill get on the clutch, the rpms will drop to a little below idle, and then bounce to a little above it before settling in at normal. i'm guessing it's something most of us experience and is not an issue. i'm not stock anymore, but it would bounce just the same when i was stock.
I don't believe there are any leaks. It doesn't have a loud noise coming from anywhere unusual. I have a feeling it might be that my rpm guage is off a bit. I remember it going lower right around the time I did the LED swap. Do you know if the rpm gauge adjusts itself?
Wow 500, Does it feel like it will stall? im curious. and add me on the list of the needle going up. I noticed this especially right after i put in the brothers lightweight crank pulley. But there are people saying that they have this in a stock TC? then phew i feel better maybe i just dint notice before.
phew, good to know im not the only one out there, and i was always afraid to go to the dealer too cause of the amount of work done to the engine, and their easiness to blame everything ona mod... but mine does it when im coasting or coming down a high speed, roughly from about 50-ish, and drop into neutral and then i see the revs drop to about 600 then bounce up to 1300-1400 and repeat several times until i slow down to a crawl or put back into gear... if anyone can think of a reason... maybe a leak or for alot of us, a common mod that somehow caused it?
Cant be a mod some of people on page 1 i think said they have too with a stock tC. My car is only about 4k miles so if itz a leak then omg itz another problem that just makes toyota look bad.
Yeah it just sucks. I mean 16k is still alot of money and ijust wished toyota fixed the small things. Like hatch rattle. Even if things are covered under warranty i shuldnt have to go back to the dealer to waste my time. But thats another story. Good to know i dint break anything.
