S-pipe install question
So, before buying a replacement s pipe I took a look under the car and it looks like the stock header is welded to the stock s pipe. Is this an illusion? How are they connected? Is this going to be a beotch to install?
heres the deal.dont try to take out the 02 sensor while its on the pipe underneate the car.just unclip the 02 sensor unbolt the bolts then while the s-pipe is out then you can take out the 02 sensor its so much easier then trying to hurt your self under neathe the car..
Many (almost every tc ive seen) are crossthreaded from the factory or are installed in a manner that when you try to remove them, they crossthread. Luckily my primary wasn't like this but my secondary was. My two buddies (one with an 06 and the other with an 09) had factory manifolds and both of their primaries were crossthreaded to hell from the factory. We used the O2 sensor removal socket on both FYI.
but yes, getting it out was a PAIN. FWIW my experience - I managed to break it free with a large adjustable wrench and at least 75% of the way out the sucker was still tight.
Good luck to OP.
If it's a secondary, wrench and re-cross thread it back in. It's garbage at this point but will still get proper flow and not leak so you won't throw a CEL. The primary (in my experience with 2 friends cars) likes to stop functioning for whatever reason when taken out of the stock manifold if cross threaded from the factory. As long as you pick up a 0-3v Air/Fuel sensor replacement from Advance Auto or Autozone then it'll work fine. The primary is NOT an O2 sensor. It is a wideband air/fuel sensor. VERY important to engine efficiency and power.
I don't know what brand mine is. I got it off a buddy for free and it's shiny It fits like a glove though! You'd be better off asking the N/A guys which fits best because most turbo guys get a turbo exhaust or get custom made setups.
Unfortunately, only one way to find out... I know Megan and Invidia pipes fit perfect but there is this company called Mandrel USA or something like that that makes s-pipes for our cars out of any one of 4 materials of your choice (price difference) and I've heard they fit perfect also. Just a cheaper alternative to random company names on e-bay.
MN Scions
I have the cheap ebay one, fitment was pretty good. The gasket you get with it is junk though. If you use the gasket that it comes with you will have a small exhaust leak but its not anything major.
The install was somewhat of a pain in the ___. I managed to do it in my garage with only hand tools and some PB Blaster to break all the bolt lose. All in all it took me about an hour to do.
my06tc
06-25-2015 12:18 AM
wiltonhall
01-28-2015 03:46 PM
Beesh
01-09-2015 06:30 PM
TheRedBox
31
12-02-2003 04:53 PM
