Scion tC Clutch problem.
Old 05-05-2010 | 06:00 PM
allfe777's Avatar
Unhappy Scion tC Clutch problem.
hi i own 07 Scion tC. just yesterday some how i couldnt engauge it in to any gear. i own a stock one too. but some how magically i can engauge it to gear today.
what can be possible wrong? some of ma friends say it can be clutch. or some of em say it can be fluid. .... can u please help me?
Old 05-05-2010 | 08:13 PM
MrBurrito's Avatar
how many miles on the car it can be the clutch and make sure to check your brake fluid.
Old 05-05-2010 | 08:20 PM
allfe777's Avatar
i have 88k on my car and break fluid seems like in line between max and min. it works fine right now. any other way can mess with my clutch???
Old 05-05-2010 | 08:28 PM
TCpete's Avatar
is the pedal on the floor and cannot go up on its own?
check for leaks on/around the slave cylinder and also the area around the master cylinder for the clutch...
check to see if the push rod on the slave has come out of place
check for inconsistent pedal pressure on the clutch pedal
check behind the clutch pedal and look at your engagement to see if the nut that holds the rod tight in its place is not loose and has moved on its own
Old 05-05-2010 | 09:02 PM
allfe777's Avatar
it dose move back up its on. but some how when i pressed it yesterday. i couldn't put it in to any gear. it flet like some out clutch plate wasnt disengauged... and from shift *** i couldnt put it in any gear. as today it seems like its working perfecly nomal. its very intresting isnt it?
Old 05-05-2010 | 09:56 PM
allfe777's Avatar
i guess i just have to take it to dealer to find out what is actually wrong with it
Old 06-08-2011 | 02:50 AM
JACQUIR007's Avatar
Default ANY UPDATE???
my car seems to be having the same issue. what ended up being wrong?
Old 06-11-2011 | 09:29 PM
Bruno769's Avatar
my o6 tc has this same problem.i changed the slave cylinder and it worked for a day.later that night i had no clutch. i'm taking tranny out right now
Old 07-03-2011 | 05:10 PM
s_rhabb's Avatar
Team Scionara
Did you find out what happend?
Old 07-05-2011 | 05:26 AM
Bruno769's Avatar
Default 06 clutch problem
i ended up putting a new clutch in it...when i removed the old clutch assembly the rubber grommets and metal clips in the disc were gone and wedged inside the pressure plate...
Old 07-05-2011 | 05:28 AM
Bruno769's Avatar
i used tennythetc pics and illustration to remove the trans..then i went to autozone.com to get all the torque specs to put it back together
yhwhdesign
10
02-06-2015 06:00 AM
BrokenTC2
01-27-2015 04:32 AM
Xaphoon
01-17-2015 03:12 AM
baker08tc
12-30-2014 01:02 AM
JM Auto Racing
12-19-2014 07:36 PM
