Shift Bushing Question...
Just installed my TWM performance short shift as well as bushings...
When I installed the shift bushings the instructions said that the bushings were different, and that one goes on the lower vertical spot.. and one on the higher vertical spot. But I couldn't figure out which one they were talking about... is this going to cause a problem? Or does it even matter. I wasn't sure since they are made for a celica..
My fidanza short shifter came with bushings and they all looked the same to me, I figured they all came with the same sized bushing.. I didnt install them though. I noticed though that it could be a problem having higher ones installed in the front two bolts because it would be a leverage issue and would pull on the shift links too much.
BlingSlade
10-19-2016 12:39 AM
