Shifting?!
Shifting?!
Can someone please tell me what rpms to shift at or when the peak power is. I have an 07 TC stick.......please tell me someone knows. It seems like when i get it up to redline and shift it doesnt pull into the next gear and seems like it loses power around redline. Thank You
You're right. The engine does loose steam on the top end. I'd call "when to shift" a butt-dyno thing. If you get into the higher revs, you shift, and the next gear seems to pull STRONGER than the one before it, you waited too long. Someone's going to quote you a specific RPM. But unless they've dyno'd your car and then done the math with the gear ratios, their number is most likely going to be from their OWN personal experience. I think the only surefire way to figure this out is to find some quiet roads and blow about 1/2 tank of gas. And if you get stopped by the fuzz, call it "empirical research". :D
i'm not 100% sure, but if you want to shift for fastest acceleration, you want to shift so that the tach is where your peak torque is, and then stay in that gear until you reach the rpm where peak hp is and upshift. whatelse...doesn't vvt-i kick in during like the mid 3k rpm area?
This isn't V-TECH.
thats whut happened to me to bro...like....if i shift around 6k then floor it...i gets back to 4500 rpms..but when i redline it, then floor it it drops back to 3k rpms....or .
..........i prolly misshifted those times!!!!!
Re: Shifting?!
WRX1316_TcVicent
07-22-2021 06:06 PM
