View Poll Results: Which size resonator should i get?
one 22 inch magnaflow 2.25 resonator
75.00%
2 14 inches magnaflow resonator
25.00%
Voters: 8. You may not vote on this poll
which size resonator should i get?
Old 06-16-2007, 08:04 PM
IcetC's Avatar
Default which size resonator should i get?
need to know which would be the best size for my set-up
i have and injen short ram, dc headers trd exhaust stock midpipe n s pipe
which size should i get?
just think of this as putting on a universal set-up cuz i don't want to start an argument or controversy thanks everyone!
IcetC is offline
Old 06-17-2007, 12:00 AM
SF2K4's Avatar
I read that one of the Aero mufflers (which are only like 12"-14") did a fantastic job of combatting the rasp... I have a Megan mid/s-pipe, HKS axleback, and Megan header with a Magnaflow HiFlow cat welded on which doesn't leave much room (unless I just cut off the Megan resonator) for a big 22" one from Magnaflow... so I've been thinking about trying the Aero route. Just some food for thought.
SF2K4 is offline
Old 06-17-2007, 04:40 PM
CSOCSO's Avatar
i have 22 inch magnaflow and rasp rasp rasp... try two aero muffler
CSOCSO is offline
Old 06-17-2007, 07:37 PM
IcetC's Avatar
bump for more replies
IcetC is offline
Old 06-17-2007, 07:46 PM
fujita_TC's Avatar
i have a mmw header/s pipe and megan full cat back exhuast...it was soo embarrasing to drive it sounded like a lawn mower between 2500-5000 rpms, but after cuttin off the megan "resonator" from the catback then replacing it with a 30" resonator, boi it sounded like there was no header, so i suggest gettin a 30" or 28" or 2 14" i think 2 14" wud work better if u have space...
fujita_TC is offline
Old 06-17-2007, 08:22 PM
Mugetsu's Avatar
sounds like the 2 AEROS win it...
Mugetsu is offline
Old 06-18-2007, 01:22 AM
toyota_scion_tc's Avatar
Hold on this needs to be cleared up a little bit. Just because you have a long resonator doesn't mean its wide enough. I have a Alphawerks Header, Zpi Racing S-pipe and mid pipe (the mid pipe has a Magnaflow 20" long 6" round resonator and a Magnaflow OBDII Cat, Injen Rear section exhaust, no Rasp.
toyota_scion_tc is offline
Old 06-18-2007, 01:37 AM
IcetC's Avatar
so toyota scion tc ur sayin to get a 22" 6 inch wide body and I should b good?
IcetC is offline
Old 06-18-2007, 03:07 AM
Mugetsu's Avatar
A few people have done the 6" round20"(only 14" body) i'v even seen some do a 6" round 33" long(27" body)
the tc does have room where the stock resonator sits to fit it but
the AERO are more efficient from what i hear, a AR25 which is 5"round 14"long(10" body) is as efficient as a 4"round 20"long(18"body) also they are ceramic packed so will out last any steelwool or glasspack.
a 6" round 33"long magnaflow will run you 80 to 90$
2 AERO's will run you 160$ so you do the math and decide...
Mugetsu is offline
Old 06-18-2007, 11:27 AM
My resonator is 20" long and the body is 18" long, not 14". I wanted to get one that was at least the same length as the oem one, but mine is 6" round.
Old 06-18-2007, 09:39 PM
Mugetsu's Avatar
Sorry dude magnaflow doesn't make a 6"round 20"(18"body) muffler...
they do make a 6"round 24""(18"body) muffler...
we live and learn...
Mugetsu is offline
Old 06-18-2007, 11:07 PM
My bad your right.
http://www.magnaflow.com/02product/s...ne=main&id=513
Its been on my car for a long time now and I didn't realized it was 24" overall length.
Old 06-18-2007, 11:41 PM
IcetC's Avatar
alright so from wat i have read in these rasp threads I think I'm gonna go wit the AERO I think I'm goin to get the 2.25 one bc I heard the stock midpipe is 2.35 inches so the weld should take care of that or ill let the muffler shop deal wit it ill do a before n after video to let u guys know how it goes
IcetC is offline
Old 06-20-2007, 11:50 PM
Menace's Avatar
Stock is 2.25 I believe. There is no 2.35, there is 2.5 and 2.37 (60mm)
Menace is offline
Old 06-21-2007, 08:20 PM
Mugetsu's Avatar
wrong the tc's stock exhaust diameter is "JAPAN SPEC" = around 2.35-7 inside diameter.
the Draxan exhausts were 2.35" to try to match the OEM exhausts specs as close as possible, Although Draxan themselves claim 2.5...
Mugetsu is offline
Old 06-22-2007, 03:04 AM
Menace's Avatar
Dude, search around, stock diameter is 2.25". You are telling me that Magnaflow, Agency Power, and Megan, all downgrade your diameter to 2.25"? What you are talking about is 60mm which is a popular exhaust spec overseas and that equates to 2.362" in diameter which is not the stock size of the tC. When I slap on my skunk2 (also 60mm) tomorrow, I will take a picture of the stock tc exhaust measurement for you.
Menace is offline
Old 06-23-2007, 12:03 AM
Mugetsu's Avatar
Do it then we can put this to rest.
it just doesn't look 2.25 to me at all.
do me a favor and measure it from the MID-PIPE at the flange were it bolts to the S-PIPE.
I hope your honest enough to admit if your wrong...(my entire stock exhaust is in storage so i can't measure it)
Mugetsu is offline
Old 06-23-2007, 04:59 PM
Kall's Avatar
I'm on the resonator dilema as well, doing some reseatch to find out what is the best rout or a custom exhaust. From what I have been reading, two resonators with same size won't do any better than one. Apparetnly, the first resonator will eliminate (or reduce) the specific tone for that size. Then, the second resonator has nothing (or almost nothing) left to resonate on that specific tone. Since someone already posted that a 22 is still rasp, I would go with one 14 and 1 some other size.
Ask people about my theory because I'm no expert, so I may be very wrong. That's my 2 cents
Kall is offline
Old 06-23-2007, 06:32 PM
IcetC's Avatar
it seems logical and after searching through all of these rasp threads i'm starting to understand it more i think i might go wit a 14 n see how it goes and then if anything have another one put on
IcetC is offline
Old 06-24-2007, 03:45 PM
Menace's Avatar
Mugetsu, I am still working on measuring it, got the stock exhaust in my house but cant find a tape measurer.
I would not recommend anything less than 18" if you are getting just one res. Unless its that aero one which is 12" but I heard good things about it on different threads
Menace is offline
Quick Reply: which size resonator should i get?
