Slow AT shifts during Nitrous
Old 10-31-2006, 01:16 PM
XD40tC's Avatar
Default Slow AT shifts during Nitrous
So during WOT w/o nitrous my shifts are quick and crisp. During nitrous runs they are long. What could this be? Is it because of all the power the transmission is receiving or because the nitrous doesnt turn off during shifts? Im thinking a window switch will fix this problem some but maybe I just need an engine damper? Oil was changed on the transmission like two weeks ago and yes I have a transmission cooler installed.
XD40tC is offline
Old 10-31-2006, 04:58 PM
XD40tC's Avatar
Anybody? Perhaps you turbo AT guys are experiencing the same thing?
XD40tC is offline
Old 11-01-2006, 06:01 PM
TheQuietThings's Avatar
the only thing i could guess at is the transmission is unable to handle the power and is slipping
otherwise i have no idea - hasnt happened to me
TheQuietThings is offline
Old 11-01-2006, 11:55 PM
XD40tC's Avatar
Guess some internal upgrades should be in my plans then. That or I'll just get another car lol.
XD40tC is offline
Old 11-04-2006, 01:38 AM
mike6789k's Avatar
how much nitrous are you putting in? try stepping down to a 35 shot and see what happens!
mike6789k is offline
Old 11-04-2006, 06:22 PM
sciontctuner87's Avatar
i have an 05 tc auto with a 50 dry shot and my shifts are great i run a 16.3 without it and 15.0 flat... my rpms never go below 4500 and i lunch at 2200 rpms
sciontctuner87 is offline
Old 11-04-2006, 06:23 PM
15 flat with it sorry
Old 11-04-2006, 06:24 PM
Hayden ATF Cooler where can i get this and does it do anything???
Old 11-04-2006, 06:39 PM
tikbhoy's Avatar
its slipppppiiiinnnnng
tikbhoy is offline
Old 11-04-2006, 07:10 PM
mike6789k's Avatar
how do you launch at 2200 rpms?
are you neutral dropping it? (that's horrible for your tranny... not to mention that you are running nitrous on top of that stress.... youch!)
Old 11-04-2006, 07:28 PM
brake torquing!
Old 11-04-2006, 08:11 PM
mike6789k's Avatar
does brake torquing really help? doesnt it put stress on the engine and tranny?
Old 11-04-2006, 08:23 PM
yea it puts a ton of stress on the transmission
its really not good to do lol
Old 11-04-2006, 08:30 PM
hey if you are running nitrous you really arnt worried about that kinda stuff but it is more the brakes than the tranny and it is not going to hurt anything at all if you are doing it at the tree for like 1 sec come on guys and yes brake torquing really helps
Old 11-04-2006, 08:35 PM
not really, it is much more then tranny. That is a lot of torque to be holding back. it is also making A LOT of heat in the tranny. stress and heat are the 2 main reasons why AT's break down.
Also, theres lots more stress on the brakes when stopping at 50~ mph then there is when youre brake torquing. Theres no actual friction between the rotors and the calipers when the car isnt moving
Old 11-04-2006, 08:40 PM
ok still it makes the car faster of the line
Old 11-04-2006, 08:52 PM
mplex2000's Avatar
Everybody that races an auto tranny has to powerbrake it. That's the only way you're going to get a decent launch. Plus you'll need to shift it manually, as opposed to what I saw a bunch of people saying in another thread ("just let it shift itself, that's the best").
mplex2000 is offline
Old 11-04-2006, 09:05 PM
jovan_gonzales's Avatar
Isn't shifting an auto like a manual really bad? And besides when you do that, the engine shifts even slower in my opinion because you have to take your foot off the gas. Eh, maybe it does work but I haven't been able to make it. lol.
jovan_gonzales is offline
Old 11-05-2006, 12:27 AM
XD40tC's Avatar
Dude you dont need to shift it manually. Basically what I think will fix my problem is getting a window switch to cut off the nitrous right before it shift. 6100rpm. And NO i will not go down to a 35 shot!!!
XD40tC is offline
Old 11-05-2006, 01:42 AM
mike6789k's Avatar
why wont you go down to a 35 shot? that will let you know if the tranny is slipping because of too much power... if the tranny still is acting up on a 35 shot, then you know you have other problems...
a window switch wont help between shifts, you pick two RPM levels and nitrous will only spray in those levels... usually 3000-6100 is a good range... during a shift you are definately in that range.... so tell me again, what's the point?
maybe that's your problem, you put oil in the automatic transmission fluid lines!!! also, consider using synthetic atf as it will keep temps down!
don't waste money on a window switch if you think it's going to help your shifts (it wont, but it would help you from triggering nitrous at too low of an rpm level...
good luck! and I hope you get some help from my advice
Quick Reply: Slow AT shifts during Nitrous
