SOUND CLIP -Alpha Werks header/Weapon-R intake/Injen exaust
Alpha Werks header/Weapon-R intake/Injen exaust.
I still need to do the s-pipe. I'm not sure what kind of difference it will make in the sound. I'm also not sure if the sound will change after the header has been used a while. This was after it was just fired up for the first time.
On another note, BEWARE! when you install your own header. The air/fuel ratio sensor could possibly be fused into the stock exaust manifold. Mine was and the threads were damaged when it was removed. This part was $219.00. I would advise having the dealer install it if you can, just to avoid having to replace this part. If they take it out and it is screwed up, they pay to replace it.
Ive heard that a header setup with the stock s-pipe can be raspy at high rpms near redline, but hard to tell on you clip. You need to rev to redline for full effect... didnt sound like you went much over like 4000-4500 rpm. But sounds real good in that clip.
oreoremix42
04-08-2015 01:06 PM
MagnaFlow
103
09-03-2005 03:40 AM
Kodokan_4
12-31-2003 05:47 PM
