Stock Oil Pressure
Old 08-01-2008, 03:39 PM
garabaldy's Avatar
Sorry I didn't get back earlier but I verified the cold idle PSI at 45
garabaldy is offline
Old 08-01-2008, 05:02 PM
B_Real45's Avatar
Thanks, Garabaldy.
What do you think - should I run a restrictor (biggest one I can find) on a journal bearing turbo? I know most people don't do it - but I figure since the seals are only designed for up to 30psi, yet even though they can hold more, I rather play it safe.
We didn't use on my friend's Garrett T04E 57trim in his 'Teg - but he hardly got on the car at all.
B_Real45 is offline
Old 08-01-2008, 11:51 PM
Ronin Scion
Ace83's Avatar
I say its safe especially if you are an aggressive driver and your oil pressure is always on the high side.. there are bigger oil restrictors designed for non ballbearing so just get those
Ace83 is offline
Old 08-02-2008, 01:50 AM
enjoithis's Avatar
anyone have a link to an oil restrictor?
enjoithis is offline
Old 08-02-2008, 02:36 AM
Ronin Scion
Ace83's Avatar
A 0.60 orifice is common for t3/t4 or non BB, try this link
http://www.intengineering.com/Shop/C...id/0/SFV/32093
try ebay or google, here's what im using on my gt30 turbo.
http://www.atpturbo.com/Merchant2/me..._Code=ATP-FTG2
http://himni-racing.com/index.php
make sure you choose the right fitting
Ace83 is offline
Old 08-02-2008, 03:27 AM
toyota_scion_tc's Avatar
Originally Posted by AcidDrop
^are you using a sandwich plate for the gauge, if so which one?
I'm lost what do you mean?
toyota_scion_tc is offline
Old 08-02-2008, 08:46 PM
AcidDrop's Avatar
i mean a sandwich plate adapter so you can hook up the oil pressure sensor to it or how did you connect the sensor and where?
AcidDrop is offline
Old 08-02-2008, 08:50 PM
Ronin Scion
Ace83's Avatar
^^ I assume the more common way, "T"d on the block where the oem oil sensor is
Ace83 is offline
Old 08-03-2008, 02:22 AM
This is how I did it b/c I want to know the oil pressure at the turbo.
Sooby
Scion tC 1G Wheel & Tire
11
04-08-2020 11:51 PM
my06tc
06-25-2015 12:18 AM
SloTC1
04-02-2015 07:11 PM
darkshadowofxdeath
12-03-2014 06:59 PM
eric_m
79
03-17-2013 12:21 AM
Quick Reply: Stock Oil Pressure
