stock Panasonic battery question
ok i have a 05 tc (got the car sept 04), with the original panasonic battery still.. i have 108K, the battery seems to be running fine... but was thinking maybe i should look into getting another one of these awesome batteries... how much do these panasonic batteries cost? and what are the specs of the original battery.. like CCA; maybe another brand is equal to it?
thanks
thanks
Yeah those batteries are incredible. I'm right at 100,000 miles and I just had to change mine after 6 faithful years of service.....it would have probably lasted longer but I moved from Florida 3 years ago to 7000 feet above sea level here in New Mexico and it has had to endure some harsh winter exposure at high altitude, and finally gave out.
So I bought the $200 Optima (red top) battery from Autozone 2 months ago. It's fully sealed which means it's a little bit better protected from the elements (and you could mount it upside down if you wanted lol.) I like it so far but only time will tell if it's as good as those Panasonic stock batteries. If you can find one I say go for it, but other than the Stealership, I don't know where else you could find one, and they are probably really expensive (think around $300) since they are OE equipment.
thanks
thanks
The brands johnson controls makes the batteries for are, toyota, honda, autozone, to name a few. the website where the company lists it, is here
http://www.autobatteries.com/brands/index.aspx
the CCA was 580 or 585 for the stock battery, I believe. the one I looked up at autozone (duralast is their brand), just the regular one was 600cca. when you do get a battery take a multimeter/voltmeter with you to check the voltage, anything below 12.6v i wouldn't buy, not good. If it checks out to be 12.7 and above, it's a good battery. That's my rule I go by.
you can also have your stock battery load tested at the dealer, they can give you a printout from the handheld tester to show you what it tests out at. There is a "state of charge" (soc) i think i remember seeing it.. it shows the quality of the battery on a bar chart. that's really good to see. some dealers do a test like that as a courtesy.. might wanna see where yours is testing out at, if the dealer would give one to you for free.. but for me i wouldn't spend over $100 for a dealer battery, you can get one for cheaper elsewhere, and it's the same exact quality.. if you do need a new one.
Same here as well, 04 and at 80k. With some cold temps this winter it cranked just a little slower but never ever gave out. Even though it is a "maintenance free" battery I topped off the water ( distilled of course ) level since it was getting too close to the low level mark. It made no difference but for $3.00 worth of water Its good insurance.
carid
12-04-2014 09:35 AM
darkshadowofxdeath
12-03-2014 06:59 PM
