Terrible gas mileage after a/c compressor install
I just recently replaced my a/c compressor, condenser and waterpump on my 2005 Scion Tc with 112000 miles on it. I just did a road trip to OKC and got 304 miles on my full tank of gas when I had my a/c running. Under normal circumstances in the city with or without a/c before the install I got a minimum of 320 miles or so and usually 340+ on highways. I did not have any issues on my Colorado road trip earlier this month before the install.
It definitely seems like it slows my engine down considerably when I turn on the a/c. Has this happened very often? Is it due to buying an aftermarket compressor? It should be noted that my a/c does not work as well as it did, it blows cool, but not cold air now. I need to see what the mileage is without the compressor on, but it's still kinda hot.
Any ideas on what I should do to make it function better?
compressor kit I purchased off ebay. $345
http://www.ebay.com/itm/170637701841...84.m1497.l2649
Water pump $28
http://www.ebay.com/itm/150623855602...84.m1497.l2649
Condenser $75
http://www.ebay.com/itm/270930875499...84.m1497.l2649
I paid $450 to install everything.
Water pump $28
Condenser $75
Maybe the pulley creates more drag than the oem one? Like the bearing isn't as smooth as the old one? Change in elevation? Running it more? Gas mileage has a ton of ____ that could effect it
Sent from my SCH-I535 using Tapatalk 2
Assuming the new compress is ok.
If you unplugged the battery, then the ECU is relearning.
I believe all ECUs have a Short Term Table/Long Term Table, where it adjusts timing/fuel accordingly. For the first few hundred miles.
Are the bearings ok in the new compressor?
I am pretty sure it is directly related to the Compressor. I never had any issues with gas mileage being below 320 mpg even driving hard core in the city. I estimate a 15% reduction in mileage when using the a/c. Will check the difference with using no a/c once it cools below 100 degrees after this week. Normally I averaged 26mpg normally and close to 30 highway. I barely got 25 on the highway using the a/c.
Edit:
Not sure on the bearings. Will have to see once I change out my drive belt soon.
Edit:
Edit:
Edit:
evolving_machine
10-21-2023 01:16 PM
