ticking sound with cai
Old 03-01-2006 | 01:56 PM
  #41
bbsciontc's Avatar
on another note, my CAI seems to be bumping the metal on the opening to the fender, mainly during initial start-up and shut-down. I did put the rubber trim over the opening so it is actually hitting against that, but I'm sure over time it'll wear through. Any suggestions to maybe brace the piping at this location so it wont bang anymore?
Old 03-01-2006 | 05:20 PM
  #42
wc01's Avatar
so that solves the mystery of the infamous ticking sound.ONE MORE THING DOES ANYONE ELSES CAI RATTLE DURING START UO AND SHUT OFF OR WHEN YOUR IN TOO HIGH OF A GEAR LIKE WHEN YOUR BOUT TO STALL OUT/
Old 03-01-2006 | 05:57 PM
  #43
Friek's Avatar
Man I am glad someone posting a topic about this... cause I just removed my intake, thinking it was something serious I was about to take it to the dealer. But I guess once the weather clears up its goin back in and maybe a little fabrication of a silencer or somethin.
Old 03-01-2006 | 07:08 PM
  #44
Sanjuro's Avatar
I actually used a thick rubber gasket from Lowes (hardware store) plumbing section that had a bit of a "L" shape to the lip. It fit PERFECTLY in the hole and there is 0 movement with the CAI. It allows for just enough flex while keeping it from rattling. Hope that helps.
Jay
Old 03-01-2006 | 09:10 PM
  #45
Batjew's Avatar
yes, but i've had trouble bolting it down good, so it just rattles from vibration, i just gave up. and my car is an 06
Old 03-01-2006 | 09:43 PM
  #46
TCpete's Avatar
Jay
got pics of that?? thats an interesting solution
Old 03-01-2006 | 10:28 PM
  #47
Sanjuro's Avatar
Sho-nuff...I just snapped these. Pardon the dirty engine bay, haven't cleaned it all winter.
Here you can see the rubber gasket that came with the CAI was placed over the firewall opening top and bottom, and larger pipe washer was placed around the pipe and slid into place with it. The part you don't see is the bottom of the "L" lip running under the edge of the hole. It holds firm, and although there is some cracking visible (had to stretch the heck out of it to get it on) I shouldnt have to replace it for a couple of years.
jay
Old 03-01-2006 | 10:37 PM
  #48
wc01's Avatar
also did anyone have to remove their bimper to install the cai
Old 03-01-2006 | 10:50 PM
  #49
gwtc's Avatar
I didnt, all I did was removed the driver side wheelwell(don't have to remove it completely) jacked the car up on the driver side so I would have better access to it, thats all.
Old 03-01-2006 | 11:26 PM
  #50
bbsciontc's Avatar
Thanks sanjuro... very creative solution. I'll stop by my home depot this weekend and see what I can find
Old 03-01-2006 | 11:39 PM
  #51
wc01's Avatar
thanks for the heads up when i covert it to ca
Old 03-01-2006 | 11:44 PM
  #52
gwtc's Avatar
No prob. good luck and have fun .
Old 03-02-2006 | 01:17 AM
  #53
therearetimez's Avatar
Default trd cai
you guys think that the trd cai will have taken note of little things like the ticking. in other words will the trd cai pefect and over come these little problems?
Old 03-02-2006 | 01:33 AM
  #54
wc01's Avatar
I ASKED THAT SAME QUESTIONED BUT NOBODY DECIDED TO ANSWER
Old 03-02-2006 | 02:21 AM
  #55
SF2K4's Avatar
Ok, so, would everyone still recommend the Injen CAI? I see a lot of resentment about some things and mine's going to be here for this weekend's isntall... I just don't want to regret it once it's on.
Old 03-02-2006 | 02:24 AM
  #56
wc01's Avatar
i would get it. today there was no ticking sound at all i guess it has to do with the temp it was 77 today but the growl it makes is well worth it
Old 03-02-2006 | 05:04 AM
  #57
SquallLHeart's Avatar
the VSV comes on and off as it needs to.... it's gonna tick... regardless of CAI or not (for those asking about the TRD CAI thing a few posts up..) and yes... from my understanding it does have to do with temp.
it's not a problem... it's just doing it's job...
Old 03-05-2006 | 07:54 PM
  #58
Friek's Avatar
nice DIY fix. I think when I re-install I will have to do the same thing. Thanks man.
Old 03-05-2006 | 08:34 PM
  #59
SF2K4's Avatar
The install was a pain the toosh, but now that it's over I'm glad I did it. The CAI sounds great (haven't heard the ticking at all, obviously due to temp and it's HOT in Dixie right now...) and looks great, too (minus some installation scratches). I used some foam pads and electrical tape to prevent vibration where the tube enters the fender. Foam allows a lot of flex but no rattles/wear.
All in all, very pleased.
Ravendarat
06-09-2015 02:25 PM
hampton1100
05-28-2015 08:32 AM
CrowJenkins
05-04-2015 05:52 AM
D_Roke
03-31-2015 06:37 PM
corbmonster
01-24-2015 06:22 PM
