TOWING! help?
TOWING! help?
I've got a trip to make from FL to CA with a U-Haul 4'X8' trailer. Just wanting to know if anyone else has towed so much without any problems?
-yes, I know the Scion tC is not made for towing. But is it possible and has it been done?
What do you guys think?
Thanks in advance!
Thanks in advance!
Sorry you got all this bad information last year. A 4x8 Uhaul trailer is easy to tow. Toyota doesn't rate any of their cars for towing in the US... but rates them all for towing in other countries (except the Prius).
I towed this for about 300 miles and got 31-32 MPG doing it!
anyone else have experience using tow hitches?
i am thinking about getting something like this
http://www.etrailer.com/Trailer-Hitc...eid=2007208572
then attaching one of these on there
http://www.discountramps.com/motorcycle-carrier.htm
i know some people have probably done bike carriers but has anyone done a dirtbike carrier?
my friend used his xA to tow a motorcycle trailer from north of detroit, to kentucky. then back with a bike on it. i forget where he got the hitch from but he got the trailer from uhaul.
Will Uhaul even let you rent the trailer to tow behind a tc? As far as I know, they will inspect the car you're hooking their trailer up to, to insure its rated for the load. Im thinking that would be your first problem. 2nd, I wouldnt ever tow anything with a tC - just doesnt seem like a good idea - the suspension on the tc is designed for 800 lbs of payload at max. Once you have you and a passenger, than you add the trailer, Im thinking its going to cause some issues. I have a feeling you could loose control of the trailer on a windy open highway or steep downhill grade pretty easy. Remember, you need to think about the worst case scenario - what happens if the car in front of you makes an emergency stop, would you be able to do the same with the trailer behind your tc? just my opinion though - never have and never will try it. I have a Tundra for towing, in fact it will be towing my tC to Asylum tommorow.
Im just talking about a hitch to put a dirt bike carrier on it. my bike weighs less than i do so im sure the car can handle the weight.
i just wonder if anyone has experience with a good hitch kit.
FreedomPenguin
Scion tC 2G Aero & Exterior
06-08-2015 05:19 AM
SpaceCaptain
05-11-2015 06:24 PM
