TPS Reading at Idle Question / Running ZEX N2O 65shot
Hey long time reader new poster, I cant find the answer to to my question so I figured Id ask. I'm having issues with my nitrous kit. (I installed it, & have had it bench tested by ZEX since the first instal but I'm still having issues. The solenoids kick in when the peddal is at 2/3-3/5 to the floor. IS anyone else having this or Do I have a bad TPS?)
Hey guys, I have an '09 tC RS 5.0:W/ Crank LW Pulley, CAI, CAT back, AEM F/IC and 93 pump tune ZEX Wet KIt and ZEX TC Window Switch
I'm running a ZEX nitrous kit on a 65 shot w/ tune and 1 range colder ZEX plugs. I have an Aeroforce Interceptor scan gauge. (for those who don't know) The ZEX kit works based on the TPS sensor being at WOT. On my scan gauge reads my TPS is at 17 at idle. From what I've read on other forums (mustang only) the TPS should read at 0. MY question is do I have a faulty TPS or should I move the TPS (white wire) to the TPS wire inside the car vs. the TPS on the TB? I know there's two TPS wire on the TB & I have it wired to the correct wire per ZEX instruction. WOT has never read 100... Is it always at 17 or is my TPS bad?
I dont think the drive by wire will ever let you truly see full WOT. But as far as a fix for your problem goes, this is beyond my realm of knowledge. You should definitely meet up with me though! I am in Grand Rapids. Do you get your tuning done at Force?
That's the same for my WOT too, I misspoke, the NMU reads the voltage & the WOT reading 80 the voltage is supposed to be at its highest. (the NMU thinks its 100%) its only suppose to kick on when the pedal is to the floor. The problem being that it kicks in too soon, so I thought it might be w/ the TPS Zex suggested I re-locate the wire to inside the car v. Off the TB wire & hard wire it there. I'm not even sure where that TPS wire is though, I think its in the kick panel box / OBDII connector, but idk which one. The car is still in storage since there's still snow on the ground here cpl more weeks
Ill be installing my N2MB WOT box in a few weeks and I am pretty sure that involves splicing into the TPS wire at the pedal. Ill keep you posted then maybe I can just show you where it is.
I just helped a friend of mine install one of those on a '98 cobra, the instructions weren't the clearest. On cobra's that's wired in under the hood. Just curious what are you planning on setting it up to launch at? Those things are pretty bad-___, a little nerve racking trying it out for the first time but they work awesome on high hp cars.
I was just down at TX2K14 in Houston, insane amount of money down there, check out there videos on YouTube by; 1320 videos or by Mexico racing league...upgrades worth more than tC's new lol
TX2K14 is a sight to see, several of the Porches down there are tuned by the tuner I go to. Garth Ruggie @ Undercoverperformance.
I'll be running a 100-125 shot this spring from wizardsofnos. (Built head and block)
https://www.noswizard.com/car-nitrou...rous-kits.html
Will be controlled through proEFI and spray on E85.
Have you already done an E85 conversion? I've looked into it briefly but from what I've read the gain makes it worth it.. what all do you need to do it? Injectors, FIC tune & a bigger fuel pump?
The system I have to run it is a flexfuel setup from proEFI so I can run pump gas and E85 anytime and it'll adjust fuel and timing according to ethonal content.
Yeah that'd be cool, thanks...
In regards to Ethanol in the Tc, I dont think the FIC will allow you to PROPERLY run ethanol. I dont think you can get the partial throttle tuned into the AFR range that alcohol likes. You should post up some info for your proEFI system. If it is in the FIC pricerange it would be a good alternative for people like us Michiganders to run E85 all year.
daniinpitt
04-04-2015 08:07 PM
Bakoscion46x
01-19-2015 02:39 AM
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
