Tranny issue.
Tranny issue.
Well i will try to describe this as best as possible. My tC (5spd) whenever I shift up to 3rd gear or down to third gear it makes a grinding noise. It goes into third drives ok, etc just when shifting into it it makes the noise. any ideas? I honestly hope its not a clutch issue and something that is under warrranty but still....
thanks
thanks
it probably isn't a clutch issue because then i think it would effect all your gears that you shift into.
maybe it is a bad synchronizer, or something is wrong with the shifter itself.
take it in, that sounds like a warranty covered problem.
I'll have it looked at on friday when i take it in for the oil and airbag recall. I keep the clutch pedal in long enough as far as that goes. hopefully it is a warranty covered issue. I had my dad and a friend check it out to make sure it wasnt my driving but they had it doo the same thing too.
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
