UnderDrive Crank Pulley. Yay or Nay?
I was told that installing a underdrive crank pulley (by OBX) is a terrible idea. That since its missing the rubber seal thing that the OEM one has, it will essentially vibrate the motor to death. What are your thoughts on this? If this is true is there a fix?
Nope, nothing wrong with those. just remember, your supercharger's RPM is directly related to the ratio of crank pulley's RPMS. If you put on a smaller crank pulley, you'll generate less boost pressure are all speeds for your supercharger. If there was space, you'd actually want a LARGER crank pulley so the supercharger would spool up faster, which is why you have a smaller supercharger pulley.
Honestly, I did notice a slightly quicker throttle response when I first installed mine but there is no DRAMATIC difference. Its not going to give you 50hp and knock a second off you 1/4 times but I did notice slightly faster acceleration.
NonStopTuning
Scion FR-S Drivetrain & Power
14
05-05-2017 06:52 PM
xjleitex15
08-18-2015 01:23 AM
