Valve Adjustment (WITH VIDEO TO MAKE SURE ITS THE VALVES!!!)
Old 11-28-2008, 01:06 PM
crush02342002's Avatar
Originally Posted by B_Real45
Good time to get some Stg1 cams and rebuild the head!
x2
crush02342002 is offline
Old 11-28-2008, 01:08 PM
i couldnt be 100% sure its the head though........id have to hear it in person.
Old 11-28-2008, 05:35 PM
HEYitzMEEE's Avatar
Lol id do it if I had 600 bucks to spend on cams! It only ticks under a certain load, when my throttle is like 2/5 pressed, it'll tick till I shift. Under full load, you dont hear it. When im on cruise control, you can hear it.
HEYitzMEEE is offline
Old 11-29-2008, 02:59 AM
HEYitzMEEE's Avatar
BUMP, Any extra help with this is highly appreciated!If anyone can help me diagnose this, a DIY will be coming to ScionLife's page!
Old 11-29-2008, 09:04 PM
HEYitzMEEE's Avatar
Bump?? Please??
Old 11-29-2008, 09:12 PM
im sorry mang the only thing i can tell you is pop the valve cover off and take some measurments with a feeler gauge. see what your clearances are and go from there.
Old 11-29-2008, 10:25 PM
HEYitzMEEE's Avatar
That sounds do-able haha. I wouldnt have to take my cams off in order measure the clearance from the lifter to valve right?
Old 11-29-2008, 10:51 PM
Originally Posted by egtc88
Yea you can adjust but not the way your probably thinking
This is what Toyota will do
Hope this helps
this is what you need to do.......some of it may not be entirely necessary such as removing all the splash gaurds. but its got all the info you need to do it.
Old 11-29-2008, 11:21 PM
HEYitzMEEE's Avatar
So I see that I'm going to need a feeler gauge, would a micrometer work as well?
Old 11-29-2008, 11:29 PM
HEYitzMEEE's Avatar
And also, that guide basically says the valves aren't adjustable. you just have to measure to clearance so only the LIFTERS are adjustable, kinda. Valves can't be tightened, but lifters can be adjusted to make sure the clearance is a-ok. Does anyone know what it could be in my video? Clearance is off and lifters tick?
Old 11-29-2008, 11:31 PM
HEYitzMEEE's Avatar
And is it possible that the valves expanded or widened? What situations would cause my lifters to tick?
Old 11-29-2008, 11:45 PM
to check just the clearence between the lifter and cam you need a feeler gauge, to check the lifter thickness then you need a mic. who know you may end up popping the valvcover off and find a busted valve spring. if you go that deep into it then id suggest getting a caliper preferably a digital one to measure the valve spring.
Old 11-29-2008, 11:59 PM
HEYitzMEEE's Avatar
I'm not sure what it is about the valve spring though, but if my valve spring was busted would I constantly hear a tick and not under a certain load? I only hear the tick at about 2/5 throttle. I hear it constantly on cruise control as well. If I go half throttle, it disappears. I've popped my valve cover off a few times and rotated my cams with the crank pulley and don't notice anything off the top. But i'll try to do some major digging and snap some pics of it hopefully soon.
I just hope that this is something I can educate myself on to save myself some money. Id rather my 367 go to boost than to toyota for fixing something I can do by researching.
Old 11-30-2008, 12:34 AM
i was just throwing that out ther, good luck and it should be a good learning experience
Old 11-30-2008, 01:25 AM
HEYitzMEEE's Avatar
Thanks a lot, when I decide to start this whole this, hopefully i'll have enough patience to post a DIY. I dont know if this is a common issue from redlining often, but i'm sure it'll come in handy for someone haha.
Old 11-30-2008, 01:39 AM
redline much.....lol
floating the valves is what happens and could mean your valves could be bent, marred from the keepers, keepers damaged, valve spring could be damaged........thes are the things you want to look at and if none of these is it then your gonna want to go deeper into things and check your bottem end. pistons, piston rings, con rods, bearings, ect.
Old 11-30-2008, 02:06 AM
HEYitzMEEE's Avatar
Yeah i've been told about all those haha. I'm pretty sure if it was something that serious, I would hear that noise consistently regardless of load. It does disappear with a certain load though. So that makes me believe it isn't that severe. I youtubed all the horrible-ness and doubt it's something that serious. But thanks haha. I'd rather have input than none so you're awesome.
Old 11-30-2008, 05:33 PM
egtc88's Avatar
I work for toyota and am in training to be a tech, thats where I got the repair manual.
Its an online manual that I have access to.
I will post the rest of the repair manual soon
and sorry but I haven't even done this yet so i cant really help much
egtc88 is offline
Old 11-30-2008, 05:39 PM
iv done it to a ka24de (nissan altima) it pretty much the same process as far as measuring goes.
Old 11-30-2008, 05:41 PM
it would prolly help to see a blown up pic of the head @tdc #1
Quick Reply: Valve Adjustment (WITH VIDEO TO MAKE SURE ITS THE VALVES!!!)
