Valve Tapping ? ! ?
Old 09-19-2005 | 02:15 PM
qbnlykwhoa's Avatar
Default Valve Tapping ? ! ?
Usually hear it at about 3.5 - 4 k RPM's. Like a metal clicking noise coming from the engine compartment. I spoke to a freind and he said it could be valve tapping and that since we have VVT-i it can be adjusted? Iam really not sure. Is this bad? Anyone else experiencing anything like it?
Old 09-19-2005 | 05:13 PM
qbnlykwhoa's Avatar
anyone?
Old 09-19-2005 | 07:00 PM
ScionDad's Avatar
Yea, I can hear that too.
Old 09-19-2005 | 07:43 PM
hahaitzskippy's Avatar
valve tapping?
Old 09-19-2005 | 11:06 PM
make_shift's Avatar
Mine does it too...Sounds more like cam followers tapping than a valve tap—if it is the cam follower then there is nothing to worry about and nothing you can do about it.
Old 09-20-2005 | 12:05 AM
toyota_scion_tc's Avatar
Default Re: Valve Tapping ? ! ?
If you really think it is valve tapping then take it to the service dept and have them look at it. That isn't true about the not being able to adjust it. Its a diffrent adjustment on the TC not like typical valve adjustments. You actually have to remove the cam to do the valve lash adjustment on the TC.
Old 09-20-2005 | 03:17 AM
Originally Posted by hahaitzskippy
valve tapping?
huh? anyone?
Old 09-20-2005 | 03:47 AM
engifineer's Avatar
With a solid lifter setup (which I am fairly sure the 2az runs) you can expect to hear more rattles and tapping from the valve train. If you are concerned, take it to the service dept and have em check it. Cant hurt to have it checked
Old 09-20-2005 | 05:03 AM
qbnlykwhoa's Avatar
thanks for the replys
Old 09-20-2005 | 05:43 AM
zach's Avatar
Wanna complain about loud lifters? You guys shoulda heard my old `93 Maxima SE (DOHC V6). They had a defect in the variable timing cam that relieved oil pressure in the cam which lead to noisy lifters, oh was that a pain in the ___ to deal with...it was so freakin loud it sounded like someone tap dancing on a loud speaker.
Old 09-20-2005 | 10:30 PM
synchro1's Avatar
I heard the same type of taping sound coming from the engine bay, but i would hear it at idle. i took it in to the dealer and they had to replace a belt tensioner. this was at like 8000 miles. since then, to tapping.
Old 09-20-2005 | 10:38 PM
Streeter's Avatar
Have a DC Sports dual carbon strut tower bar installed by chance?
Old 09-20-2005 | 10:46 PM
synchro1's Avatar
nothing intstalled under the hood but an intake so far. next week comes the header exhaust and throttle body.
Old 09-20-2005 | 11:08 PM
ack154's Avatar
Moved to PH...
Old 09-21-2005 | 05:23 PM
jmiller20874's Avatar
Throttle body? Where are you getting one of them? Size?
Old 09-21-2005 | 08:27 PM
qbnlykwhoa's Avatar
No its like a clicking noise and the harder i hit the gas the louder it gets... i start hearing it at about 3.5 - 4 rpms.... my car is bone stock... Iam guessing its the valves or something in the engine. If it was a vibration i would not always hear at the same rpm.
Old 09-21-2005 | 08:37 PM
engifineer's Avatar
^^ everything has a resonant point, so it is very possible to always here a vibration at the same rpm if that is the point of resonance for the item in question. I am still guessing valve train noise, which to some degree is normal.
Old 09-22-2005 | 02:24 AM
Harmonic_tC's Avatar
its probably that thing with the green cap and orange tag on it that you attach to the intake. It was screwed onto the stock one. Not that its attached to metal the sound carried alot more.
yupinmytC
22
07-27-2024 08:08 PM
SloTC1
08-16-2018 03:45 PM
vi3tb0i09
09-23-2015 09:32 PM
ScionLife Editor
09-15-2015 05:40 AM
