weapon r header wont budge...need HELP (pics)
1UP Crew
hi i just recently receieved the weapon r header, but i have a problem. im trying to connect the 4 to 2 pipes together, and i have them both connected, but then its a _____ to make it go all the way down where its supposed to meet. does anyone know of a way that i can join these pipes together? cuz it wont budge...i even got my fat friend to sit on it, and still nothing. please help..
1UP Crew
im pretty sure it was supposed to be cut so that it's pushed in because the two end pipes from one pice is a bit wider than the two end pipes on the other piece and it also has these pieces of metal on each piece with a hole so that it could be secured with some metal piece and bolts. so im pretty sure they didnt send it and forgot to weld it together...
my header was welded, can u show me pix of what you are talkin about so i can see it?
nm i see it in the pix, umm... well those might be so you can attach the stock manifold brackets onto the header... why dont you give MMW or WR a call and see if they can tell you wat to do
You can visit their website and check them out under the products section or call their sales office. I don't believe they're distributing them yet because they're just getting their initial special orders out.... Mine should be here on Monday and I ordered it seven weeks ago.
www.monstermotorworks.com
1UP Crew
im gonna give them a call on monday bcuz they're closed on the weekend. hey coon9573, let me know on monday when ur headers come in if it came the same way as mine...in 2 pieces...let me know bro...by the way, im pretty sure it suppose to just slide in, cuz u can tell that they test fitted it...u can see the lines on the end of the 2 pipes...its just a really tite fit...i need to figure out a way to connect those things together...or have a machine or something to do it., i dunno... i guess i'll wait and talk to weapon-r and see wut they tell me.
^^^^ i really didnt find anything funny. . .at all. i would be ____ed if i paid for something that isnt right, because now u gotta send it back and wait for another to be shipped. . all that down time could of been avoided if people only did their jobs
we got our on last week it was a snug fit but its fit together no problem.
Actually it is in seperate pieces for easier install due to the size and angle of the pipes, it should fit together no problem.
if you are still having a problem, give Ray a call monday, keep in mind that this is SEMA week and they will be going to vegas on Wed.
there are only 3 or 4 of these out right now but the rest will be in stock soon. we are the first group to get this piece. this WR header has a noticeable boost in power too!!
mikek6789 wrote:
LMAO EVEN IF YOU GOT THAT TOGETHER, GOOD LUCK WITH THE LEAK!!! LOLOL NON WELDED< LOLOLO
FYI there are no leaks due to the fit and direction of the flow
it should seal fine., just as long as you don't try to hammer those tubes to get them to slide in the other side...motorcycles you that kind of slip fit with springs......yours does have springs right?
