What is the a/f sensor?
Does it stand for airflow sensor, and can I get one only at the dealer? Yes I am changing my manifold to a header. Thanks in advance all.
i think it reads the mixture of burnt air/fuel from the cylinders. many are cross threaded from the factory, many are not. if yours begins to loosen (left) with ease and then suddenly stops, you'll probably going to need a new sensor.
I've tried everything, and it is stuck. Oh well for me, hopefully the dealership will have one on the shelf. Thanks everyone, this is why I am so happy to be a Scion owner.
I don't know what mm size the A/F sensor is, but a simple search for a 24 mm die on amazon:
http://www.amazon.com/s/ref=nb_ss_gw...words=24mm+die
yielded only about $15 + shipping & tax (if any). I guess you would want both the tap and the die to ensure that the header as well as the cat threads were clean.
Still, $30-$50 and 30(?) minutes of careful labor is a LOT less than $300... and, if it happens again, you are ready for it.
gqdabien
09-17-2015 10:23 PM
