What you guys think "short shifter"
Old 11-17-2006, 01:59 AM
  #61
hksjza80's Avatar
I just purchase a set of short shift from K2 Motors today, can't wait to install it.
hksjza80 is offline
Old 12-05-2006, 12:23 AM
  #62
tbonespeed12's Avatar
im confused if I buy the cc short shifter for 70 does it come with everything nessisary to install or do i have to buy something else?
tbonespeed12 is offline
Old 12-05-2006, 01:02 PM
  #63
web
web's Avatar
You will enjoy it. Did you get it with the dark greenish **** or chrome? Oh, BIG TIP.............when you install the shift ****, TAKE OFF ANY RING THAT YOU MAY HAVE ON. I scratched my **** up the first 2 minutes I had it so I just put my old one on.
Second tip: use a small file or dremil to trim the 2 shift cable holders down a bit (where the cables mount to the housing, not the shaft). They look like 2 " U "s. Just shave them a bit b/c the stock cable locks are a bit bigger but after that, they slide in perfectly.
web is offline
Old 12-12-2006, 03:22 AM
  #64
all4degame's Avatar
Its it harder for everyone to put your shifter into 1st or 2nd from a 5-15mph roll? After I put in my short shifter I can't get the gear into the gate. The shifter also is a bit "crunchy" during shifts. Is this normal? It's should be a grease problem because I white greased the crap out if the assembley
all4degame is offline
Old 12-12-2006, 01:04 PM
  #65
web
web's Avatar
If you're moving at about 5 mph+, it will be harder to go into first b/c of the synchro not allowing you to. 1st gear is supposed to be used primarily for getting the car moving and not to be engaged while it is moving.
What after market shifter you get? They will make your shifting feel stiffer but that's b/c they change the pivot angle of the shift cables tightening them a bit more so that you don't get any shift lag like you do with a stock assembly. If you put white lithium grease on the two main ball sockest the cables fit in and the shifter pivot housing, you should be fine. It's just the way it'll shift. If you "hear" crunching, then take the cover off and drive it around a bit like that to see if there's something in the way or if it's not aligned properly. Also, if you got either the TRD or K2 Motors shifter housing, make sure the black plastic clip that holds the wire against the left side of the stock one is out of the way and zip tied. Mine was rubbing against the housing and it sounded weird until I moved it.
Hope this helps.
web is offline
Old 12-12-2006, 01:06 PM
  #66
web
web's Avatar
Sorry, read your profile after I posted. CC short shifter is just the shaft so check to make sure the ball sockets are greased, the spring is mounted correctly and not scraping the housing and the pivot socket is greased. if you see any shavings of plastic, check your spring. That seems like what would be making the "crunching" noise as it scrapes against plastic.
web is offline
Old 12-12-2006, 01:25 PM
  #67
chrischoi's Avatar
i love mines.
chrischoi is offline
Old 02-15-2007, 06:55 PM
  #68
blacktc16's Avatar
I'm a Girl and I've been Looking at the Ebay Shifter 45-50% Left throw! I do believe by B&M. What do you think about that? Bad brand or what! Can someone help me out or where else woudl be a great place to look?!
blacktc16 is offline
Old 02-15-2007, 06:56 PM
  #69
blacktc16's Avatar
i'm sorry it was a JDM
Old 02-16-2007, 11:10 PM
  #70
chrischoi's Avatar
twm. you're paying for quality.
Old 02-17-2007, 02:10 AM
  #71
arkracing's Avatar
ARK is another option !! $129.00 +Shipping
www.arkspeedracing.com
pm me if you interested. Thanks
arkracing is offline
Old 07-25-2007, 11:46 PM
  #72
jamaican's Avatar
hey web, i was reading what you wrote and i am now REALLY interested in the k2 shifter. so i wanted to ask you (since u have real world driving experience with it) if its a good buy. any problems with it? how is the quality of the cage and shifter? it it drastically shorter throws like you say? and does it come with the metal bushings? sorry for all the questions but i like to do my research before i make a purchase. thanks in advance for your help.
jamaican is offline
Old 07-27-2007, 06:42 AM
  #73
tekstyle's Avatar
did a google search for Creative Compacts and got creative.com. does anyone know the site?
tekstyle is offline
Old 07-27-2007, 12:50 PM
  #74
ack154's Avatar
www.promotiontuning.com
ack154 is offline
Old 07-28-2007, 10:02 AM
  #75
tekstyle's Avatar
oh wut the!!! totally different from what I expected. no wonder i couldnt find it.
tekstyle is offline
Old 07-29-2007, 10:07 PM
  #76
swim666's Avatar
THE CC COMES with everything to install or do you have to buy anything else?
swim666 is offline
Old 07-30-2007, 03:46 AM
  #77
Tcguy85's Avatar
it comes with everything you need to install it but get some shifter cable bushings as well. they make a nice difference as well.
Tcguy85 is offline
Old 07-30-2007, 02:25 PM
  #78
ack154's Avatar
2nd'd.
Short shifter + cage bushings + cable bushings = WIN.
ack154 is offline
Old 07-30-2007, 04:18 PM
  #79
swim666's Avatar
Does it have to be CC or can I buy the TWM cable bushing and it'll fit??
I'm talking about this one:
http://www.twmperformance.com/bushingkits/
swim666 is offline
Old 07-30-2007, 04:25 PM
  #80
ack154's Avatar
Any of them should work just fine no matter the shifter you have.
ack154 is offline
Quick Reply: What you guys think "short shifter"
