Won't start after engine build
So I just finished building the engine and reinstalling the engine and trans. I hooked everything back up and was very meticulous with notes and pictures. Well, I went to start the car for the first time since the rebuild and when I turn the key to "on" position I don't hear the fuel pump and when I crank it over it does not start. I checked the fuel rail and sure enough no fuel pressure. I am getting one code on my scanner P0340 , malfunctioning cam sensor. I don't think this is cause of the bigger issue of not starting but you never know. Any ideas are appreciated.........
Thanks for the replies, I checked all the fuses that appeared to be related to fuel and none were blown. If anyone knows which fuse actually is the fuel pump one please let me know. I checked for voltage at the fuel pump and i was getting 12 volts but not sure if I was checking the right ones since there are like 5 wires going to the pump. BTW, the pump worked fine when I parked it 3 months ago to build the engine. I was thinking it maybe the inertia fuel cut off switch. Maybe it tripped when I reconnected the battery........
two suggestions from experience.....check your grounding of all your wires
and make sure you checked the timing...i had a friend who didnt check the timing and the valves broke right through...and then it woudnt just start, click, or crank
So I checked for 12v at the EFI fuse, all good. I checked the EFI fuse, all good. I checked the EFI relay and it is "clicking". I removed the relay and "jumpered" the connections to turn on the fuel pump manually but the pump did not turn on. Is it possible that the pump went bad from sitting for 3 months? I will check my ground and timing next.
What pump are you using? As for testing voltage to the pump - on the connector that plugs into the top of the sump assy, the wires for the pump are black (+) and white/black stripe (-). FYI, the pump wont just turn on from turning the key to the ignition position, youll have to at least "bump" the starter to get it to prime.
Update: I was messing with the Cam Sensor testing it and in the process unplugged the FIC to test the wire from there to the Sensor. once i plugged everything back in the car started and ran. I re-started the car 4 more times but on the 5th time it would not start and now I'm getting a Cam and crank sensor error codes. So I remove the FIC and plugged in a jumper plug between the two connectors that plug into the FIC and the car started with no codes. Of course ran rough with no piggy back. I then removed the jumper plug and plugged the connectors back into the FIC and car will not start and cam and crank sensor error codes. So now I'm not sure if it is the connectors not making good contact with connectors on FIC or the FIC itself.
So all is good now. I installed the new X-1 and no more problems. I'd like to thank Paul at Dezod for his help to get my X-1 modified and the PnP harness. He went beyond to ship me the X-1 ASAP.........thanks
I started with the Unichip that came with the Turbonetics kit but it was not easily tunable since i wanted to increase my boost, so I bought the AEM FIC and used that for over 3 years. That worked great except I could not drive the car anywhere else but Denver area cause it would require a re-tune. The X-1 seems good so far cause it is much more granular and you tune it by setting the AFR and it will attempt to meet that AFR. This allows me to drive the car in other locations. i'm trying to work through a few minor issues but have not had the time yet.
with the X-1 the self tune thing is nice but is that just for closed loop or does this apply to open loop aswell
