Would any of this void my warranty/
1. Agency Power lightweight pulley
2. Greddy E-Manage Ultimate
3. Dezod 880cc injectors
4. Greddy Profec boost and emanage programmer
5. Megan Racing S-Pipe
6. Dezod S-pipe back exhaust
what are you trying to do to your car?
anyway, the exhaust won't harm anypart of your exhaust really, they are just exhaust plumbing, they really can't hurt anything unless your tailpipe isn't mounted right and melts your bumper.
the agency pulley for sure, because it doesn't have a dampner to reduce engine vibrations, the emanage, yeah, if you badly tune it.
the injectors, yeah, if your fuel system messes up.
btw, why do you need 880cc injectors? even unless you are putting on a MASSIVE turbo kit, you don't need those injectors, they usually use 440, or 550.
not sure what the profect boost and emanage programmer are for.
actually, unless you are going turbo, don't bother with the emanage, injectors, and profec boost and emanage programmer.
I was copying and pasting the names of parts and accidentally pasted the wrong injectors i meant to put greddy 440cc on there, anyway the E-manage is mainly for tuning a turboed car but it also allows you to play with the fuel flow i thought correct me if i'm wrong maybe there is a better fuel managment system, but i am getting a supercharger soon, i looked into the turbo and its more trouble than its worth, thanks
okay, if your going to supercharge the car, don't modify ANYTHING!
if you modify your intake, pulleys, header, injectors ( they will come with larger injectors).
now then, you can get it tuned with a piggyback ecu, but when you take it in for service, take it out because if they see it, you warranty is no more.
anyway, the car is tuned to the max already on the stock ecu, trying to improve the engine management is pointless unless your boosted.
the only mods you can do without compromising your warranty with the supercharger is the s-pipe and exhaust.
Originally Posted by Steventc07
oh yeah i forgot, i have heard that any exhaust other than trd sets off the check egine light any truth
you can replace your s-pipe and do full dezod exhaust without getting a cel.
the trd supercharger comes with bigger injectors.
okay, a stock supercharged tc with a manual transmission will dyno about 190-195 whp.
now with a piggyback ecu and some tuning, you can get it to about 220-227 whp.
and if you have problems, you can take the piggyback ecu off, and the car will run like it did stock, and the dealership really won't be none the wiser.
but trust me, just leave it stock until your warranty is up, you never know if you'll need it, and if it goes, it can take your who engine with it. very VERY expensive without a powertrain warranty.
so leave it alone for the 5 year/60,000 mile warranty, then after that, if you still want to, and everything is running fine, you can start modifying it since you don't have a warranty anymore anyway.
i love the hotchkis sways, i had thet trd sway before that, and a dc strut tower brace before i put on the hotchkis, and they were like bolting on nothing!
the hotchkis sways tightened up the car and made it feel incredibly solid and controlled.
i have mine set softest front, and stiffest rear.
as for springs, just wait a week after installing them to get them aligned. 12,000 miles later, my tires are great.
if you get the wheels aligned immediately after installing the springs, they will continue to settle and it will be off again once they are reached their finished settling.
and with installation of the hotchkis sways, make sure you know what your doing because while the rear one is very simple to swap, the front one requires that you drop the sub-frame. not something i would trust just anybody to do.
Pretty much agree with all that draxcaliber said. An alignment runs like $60-$70 depends on where you go. If you go the TRD Supercharger route the only other things I'd add would be some extra gauges to know how everything's running: boost gauge, a/f ratio, oil pressure. I recall somewhere that if you change the intake setup when supercharged that it voids it's warranty. My question to drax is why would a header void warranty when you have a s/c? I know that changing the header will quickly turn on the CEL, the rest of the exhaust won't but the fix is quite simple.
they void the warranty with a aftermarker header because hte heat shield isnt there. Without the heat shield, it supposedly causes excess heat damage to the shaft of the s/c, and seals go bad. I think its bologna, that trd has crappy seals. but hey nothin i can do about it. If you pop the hood after driving for awhile and try n touch the heat shield... its jsut like any other header its hot as hell in there and you cant really touch anything.
actually the trd supercharger when installed by the dealership is warranteed as well as the existing remainder of your 5year/60000 milie powertrain warranty or 1year/12000mile which ever is greater and if you install it yourself 1 year/12000 mile warranty so to me its obvious to go ahead and let them install it if you have low mileage on your car like i do but if you have 45K or more screw the dealer and their outrageous fees and do it yourself
<----- toyota tech
if you have the supercharger installed at a dealership, make sure they have the ecu reprogrammer (only some do). it reflashes the ecu with a better fuel map, etc...
pretty much anything that can be linked to failure, voids the warranty. ive seen an xb denied warranty because his "stock" motor had detonation . stock motors dont do that by themselves, so toyota assumed he had been modified. that and a week earlier, we was braggin about being able to beat my buddies 5.0 by spraying *wink*
ChefRaekwon
51
06-25-2005 03:28 PM
daillestqt
05-30-2004 08:52 AM
