Would I be a fool? Header question.
All the resonator info is in this thread: https://www.scionlife.com/forums/vie...r=asc&&start=0
I love the damper. It make a big improvement in throttle response shifter feel and reduces wheel hop. Install is easy too.
MMW and the Megan have been reported to have less rasp than the Alphawerks. The MMW is much more expensive although it is a 4-2-1 design and incorporates its own s-pipe. In the 4-1 category, the Alphawerks seems to produce the most HP, but is know for creating more rasp.
Originally Posted by melvynray
i would like to do the same also.. but how do i cure that 02 sensor problem?
unless you add a cat in between the 2, so the ECM doesnt see the same amount of air flow. if you have the cat in between then the 2nd sensor wouldnt foul out.
adding the antifouler"spark plug anti fouler" is the only way to extend it away from the exhaust flow.
or go stock header
- no rasp , no cel
or go stock header
- no rasp , no cel
i did what the instigator did........worked out awesome, as for the CEL issue, mine goes on and off, but i have a code reader so i just check to make sure its nothing else.....but no problems, its quiet and has some decent pick-up.......
Re: Would I be a fool? Header question.
Originally Posted by leastbay
What would happen if I added headers but kept the original exhaust, I really want a super quiet exhaust but also want to gain more HP anyone done this?
i have the MMW header AND.. have both the TRD axle back and the factory axle back... let's just say that the factory axle back is well.. silent... when you get on it you get just a hint.. and i do mean "just" a hint of sound... and that is with the factory components...
as for headers.... if your looking for a 4-2-1 header.,.. id maybe try DC,... from what i have read and with my experience with the MMW header... it is a hit or miss on fitment.. MMW is the more expensive of the headers... i think you can pick it up now for alittle over $500.... i think the DC 4-2-1 was like 3 and some change....
now we know that the exhaust header will add power, but i see a problem in using it with the stock exhaust system...wouldnt that negate most of the power supposedly added? i mean i dont own a flow bench or anything like that but i imagine that any increased air flow out of the motor would bottleneck once it hit both the cats the resonator then the muffler, and then woudlnt all that backed up heat mess up the cats? im just saying these are the problems that come to mind when using this setup where sound levels would be the least of your issues then....if someone has proven answers than id like to hear them...what i dont want to hear is , it works on mine so there, now if you've been running this setup for 20K miles than ok you can get away with saying that, but if you've only had this setup for just a short period of time than any problems you may be experiencing wouldn't surface for a little bit.
just doesnt make sense to me to buy the header before the rest of the exhaust
^ lame.
No, it doesnt negate power childdamien. And if you're not comfortable with adding a header before your exhaust, then don't, Nobody's twisting your arm. If it doesn't make sense to you, then it doesn't, what the **** do you want us to do? Hold your goddamn hand so you feel better about reading about how we put on a header before switching the OEM exhaust? Get out of here.
