*HELP* AEM/FIC & GAUGE INSTALL. *HELP*
Old 04-10-2009 | 05:56 AM
Mrsanchez925's Avatar
Default *HELP* AEM/FIC & GAUGE INSTALL. *HELP*
i have a few questions....
first..
-There is a white wire with a Blue Stripe on it coming from the FIC and i was wondering what it is, and what it goes to.
Second..
-I also was wondering where i hook up the serial wire from the gauges.
Third...
-Where Do i get the 5volt Tap?
thank you for your help.
Old 04-10-2009 | 06:02 AM
illusive-tc-'s Avatar
Scion Apocalypse
When he says 5 volt tap he means the maf sensor that the gaugess require I think.,..
Old 04-10-2009 | 06:03 AM
correct.
Old 04-10-2009 | 06:11 AM
jsg93085's Avatar
there is a brown wire on the smaller of the 2 F/IC connectors that says 5V in, that is where the white (not striped) wire from the 4 pin connector on the UEGO gauge needs to be connected.
on the boomslang PnP harness, it is the free orange wire
Old 04-10-2009 | 06:17 AM
thank you.
but by any chance do u know what the White wire with the blue stripe is for (which is coming of the FIC harness)
Old 04-10-2009 | 06:25 AM
jsg93085's Avatar
according to the manual the solid white wire is the 0-5v analog output and the blue is for a serial connection (where you have to pin it into a rs232 connector, pin 2, pin 5 needs to be grounded if doing this type of connection)
Old 04-10-2009 | 06:45 AM
Scion Apocalypse
The soilid white wire is looped... correct? on the harness mrsanchez recieved it is.. and the white wire with the blue stripe just comes straight off and is dead ended.
Old 04-10-2009 | 07:00 AM
crush02342002's Avatar
thank you.
the white wire with blue strip comeing from the boomslang harness is for data logging...you run that wire to a switch, then you run a wire from the other side of the switch to a ground...open fic program...click on set up....click on system...click on data logging..so anytime the switch is turned on the fic will start data logging...ther is also a window to set up the parameters of how many measurements it takes in a certain period of time and when the data log starts and ends...
Old 04-10-2009 | 07:13 AM
so i only need that if im going to Data Log?
or is the wire mandatory no matter wat?
Old 04-10-2009 | 07:53 AM
its only used for data logging or to switch between two maps...it only serves those functions...in other words if you dont want to data log or use duel maps then leave it alone...
Old 04-10-2009 | 01:05 PM
jsg93085's Avatar
crush is right, that wire is for internal data logging on the F/IC
sorry to confuse you
Old 04-10-2009 | 06:31 PM
nlataille18's Avatar
so i went to the aem power forum and they said that the white wire coming from the ugeo is supposed to go into the 18pin on the 22pin connector. if i read the diagram right i don't have a wire there at all.
Old 04-10-2009 | 06:33 PM
jsg93085's Avatar
what harness are you using?
Old 04-10-2009 | 06:38 PM
the dezod PnP. i have an 05
Old 04-10-2009 | 06:39 PM
jsg93085's Avatar
did you ask paul about the uego input wire on their harness?
Old 04-10-2009 | 06:41 PM
yeah he told me to follow what AEM says
Old 04-10-2009 | 06:43 PM
jsg93085's Avatar
lol, but they didnt include the wire on the smaller connector?
did you get the original AEM harness (the one that doesn't have the sockets for the ECU plugs)? if so, just use a small screwdriver to take out the brown wire for the 0-5v in and put it on the connector from dezod's harness
Old 04-10-2009 | 06:44 PM
no i guess i have the newer one. i just plugged it in on both ends.
Old 04-10-2009 | 06:45 PM
heres the link to the page. it's about the 5th post down.
http://forum.aempower.com/forum/inde...c,23299.0.html
Old 04-10-2009 | 06:46 PM
jsg93085's Avatar
no, you just got a PnP harness and did not receive the one from AEM for the F/IC. can you post up a pic of the smaller connector that plugs into the F/IC?
