*HELP* AEM/FIC & GAUGE INSTALL. *HELP*
Old 04-10-2009, 05:48 PM
nlataille18's Avatar
yeah sure. hold on
nlataille18 is offline
Old 04-10-2009, 05:58 PM
Old 04-10-2009, 06:07 PM
jsg93085's Avatar
yep, its empty.... it needs to go in the hole on the top to the right of the orange-black...
you may be able to find the pin connector at radio shack...
jsg93085 is offline
Scion Apocalypse
illusive-tc-'s Avatar
Originally Posted by nlataille18
so i went to the aem power forum and they said that the white wire coming from the ugeo is supposed to go into the 18pin on the 22pin connector. if i read the diagram right i don't have a wire there at all.
Thats the white wire.. like I said the white wire is looped..
We are talking about the White wire with BLUE stripe!
illusive-tc- is offline
Old 04-10-2009, 06:11 PM
jsg93085's Avatar
the white wire with the blue stripe has already been taken care of. i told him it was for the serial RS232 connector if he wanted to log the UEGO directly on a laptop
jsg93085 is offline
Old 04-10-2009, 06:15 PM
thanks. so once i do this i should be able to veiw and data log my AFR's?
Old 04-10-2009, 06:17 PM
jsg93085's Avatar
through the F/IC software, yes (which i recommend since you linked to the AEMLog post off of AEM)
having it logged through the F/IC will show nearly all aspects of the engine timing and such when looking at the logs with AEMLog
jsg93085 is offline
Old 04-10-2009, 06:21 PM
yeah i'm using the aem software and have no problem logging everything except for my AFR's. i just didn't know how to connect it to my UGEO to my FIC. Thanks again.
Old 04-11-2009, 12:14 AM
Scion Apocalypse
Ok so if I want to hook up the uego into that same spot how would I do that on the 09 tc... same socket?
Old 04-11-2009, 01:02 AM
Scion Apocalypse
So which ports do I hook the Blue wire and white wire from the uego too? I also noticed the colors are totally different from the harness I have and the manuals.... but the pins are in the correct position.
Can you tell me what they are like the actual name... on the aem install... since my wires are different... and tell me the pin if you can.
Old 04-11-2009, 01:12 AM
Scion Apocalypse
Also after looking there is 3 orange wires all have stripes on the small plug...
Old 04-11-2009, 02:34 AM
jsg93085's Avatar
its pin number 18 on the 22 pin F/IC connector that you need to connect the *White* wire from the 4pin connector on the UEGO to. (when that 22 pin connector is plugged into the F/IC, count 5 pins from the left on the top row, that 5th pin is where the *White* wire from the UEGO needs to go)
most harnesses have different wire colors than what comes in the stock F/IC harness, which one do you have? if its the boomslang PnP, the wire is the solid *orange* wire that is free and has the end taped to itself
jsg93085 is offline
Old 04-12-2009, 03:51 AM
Scion Apocalypse
THE 5th one in from the left was ben 18 which was the blue white wire... hooked it up to it so whatever.. the gauges are working... so all good for now.
And just so you know on the harness kit he had was not a single all orange on the small plug.. all had stripes.
and I believe its the boomslang.
Old 04-12-2009, 07:44 PM
jsg93085's Avatar
must have been an old boomslang harness then. when i called them a few weeks ago they said all of the harnesses have a free solid orange wire for the 0-5v input
jsg93085 is offline
Andreas24
38
09-22-2015 06:23 PM
greytc
01-12-2015 09:49 PM
06ScionTc5sp1
18
12-21-2014 07:21 AM
mattjk
121
12-22-2004 10:49 AM
DjFrOsT
28
11-09-2003 02:41 AM
Quick Reply: *HELP* AEM/FIC & GAUGE INSTALL. *HELP*
