-=-Need help diagnosing problem after installing turbo.
Just swapped a turbo from one car to another (same make and model, different years though 2005 and 2007).
The turbo worked perfectly on the 2007, but once installed on the 2005 some problems are being noticed.
When the e-manage is connected and the car is started, the RPM's go up to about 2000 and then the car stalls and dies. The car does not seem to respond when the gas pedal is pressed just after the engine turns over. When the e-manage is unplugged the car will start and remain in idle, but the RPM's bounce from ~1200RPM - ~2400RPM over and over again as if I were revving the engine.
The car will drive and once in gear, it seems like the RPM bounce goes away, except when getting into boost range, the car feels like it is bogging down. If this is done for a couple of seconds, the computer throws a misfire code on #2 and #3 cylinders. If acceleration is minimal and RPM's stay under 4000, the car appears to drive normal until speeds exceed 60 mph then the car seems like it mis-fire's.
I have checked the plugs several times, replaced the plugs. Injectors were upgraded upon installation. I believe the coil packs are okay since there aren't any misfires on light usage of the vehicle. The plugs look like they are running perfect (not rich and not lean)
If anyone can help, please let me know.
take out hte e-manage
does it run correctly?
if it does then it's not hte turbo kit it's hte management system...i don't think the harness is hte same for 05 as the 07
in fact i know they aren't hte same.
The only way the car won't stall is if I remove the emanage, but as I mentioned above the car has the nasty idle bounce and misfires.
The harness on the emanage isn't PnP. It's only like 5 wires to connect. I reviewed these connections many times.
Is the emanage "active" light supposed to be steady green or blinking green?
what are your afr's?
Where can you adjust the injector settings?
I got the emanage unit from the same guy I got the turbo from. The turbo was actually designed for the 05-06 tc.... his was an 07.
The injectors were transferred from his car to mine. They are the 550's.
My concern is that it does the idle bounce when the emanage isn't even plugged in/attached to the ECU. I can't find any vacuum leaks. Cylinders misfire
ok...maybe (which would be awesome) this is the problem
Is there anything that is supposed to be connected there? I think that is where a hose ran to the CAI ... I could be wrong.... but if this is part of the vacuum ordeal.... then what should it connect to?
ok theres 2 lines going to it.. looks like the one u have it s the one that goes down to a pipe ... the other end goes to a vaccume line behind the engine... my car has a T there going to the BOV. This should solve your problem!
ok....so that didn't work.
I found a t-fitting and ran a hose from that piece with nothing on it to the t-fitting (that i spliced into a hose running from the throttle body to the wastegate)
still has the idle rev bounce...... I'm becoming stumped.
like someone posted before u will probably neeed a maf adaptor if it was on a 07.
i had the same issue on my turbo kit after i got it retuned, where it would die right after it started up. by any chance do u have anything else like a split second? i found out that on the emanage blue (if u have this emanage) there is an anti-stall feature that keeps ur car from stalling while in boost, if i remember correctly, that was causing my car to drop idle and stall out when i did a cold start. the tuner played with the settings, and temporaraliy fixed it. it wouldnt die ,but would keep revving up and dropping idle until my engine warmed up. when i got it retuned the second time the tuner found out that the split second that i had wasnt programmed correctly and that fixed my idle problems completly. i would definitley get it retuned either way, every car is different. sorry for the long post hope it helps
nate
nate
The guy that had the 07 had an adapter to make it work because it was an 05-06 kit. So my MAF was a direct bolt on... unless I am not understanding what you are talking about.
I'm ok with getting it re-tuned.... I just wanted to figure out what the issue was before I did that only because it does the idle bounce without the emanage blue connected. I was thinking it had something to do with the car. If it was the car that had the problem...spending a couple hundred to tune the car and having the same result isn't worth it.
I appreciate your help so far.
Okay.... more help needed. I realized that I may have connected the green and white wire coming from the emanage blue unit wrong. Here are two pictures of what I think should be happening... can someone verify this for me that is 100% sure about it.
lemme get this straight, the throttle body is going to the wastgate and not to the maf sensor?
try connecting throttle body to maf sensor and not teeing it off or anything, teh maf sensor reads the amount of air that goes throught he maf and senses the vac in throttle body, probably compares it and everything.
o7 maf adapter would work, go to home depot and get o-ring and just do that....as long as it seals up you're fine, the o7 is smaller than the o5 o6
