07 Dezod PNP Harness not working, Joe Paul, Please HELP!
I have an 07 Dezod PNP Harness for my Emanage Blue. Bought it back in May of this year, finally got it out of the box to plug in last night. After putting in my injectors, and confirming no leaks, we put the base map on the emanage blue and fired it up, but.......it would not start. Fortunately, my other friend had a harness for his 07 (also PNP but from Turbotoyotas) for his emanage blue, connected his harness in my car, and it fired right up, ran great around the neighborhood for a quick drive.
We thought it might be a cold start issue, since my car was not warmed up originally. So, we put the Dezod PNP harness back on my car, and same problem. Would turn over, gargle a lil bit and then just die out. We decided to test my harness on my buddies car, with his emanage blue, and the same problem, would turn over, gargle a lil bit, and then die. We used the same map on both emanages to avoid an issue with the emanage.
So after trying different emanages (same map), different tc's (same year, 07), his PNP harness from Turbotoyotas worked on both of our cars, and the Dezod PNP harness did not work on either of ours. Does anyone have any suggestions on what I should look for? Should I send it back to Dezod and see what they can find out? I know Dezod is known for their customer service, so either way works for me, I just don't want it to take a looong time to get it back and cost a lot of money to do so (ex-ZPI customer, so you understand my concern). Thanks!
i posted this in some dezod thread asking if he would replace the bad harness.
no reply yet.
its like a tease to see how fast your car was, but then not be able to have that speed again
im sure Dezod will send you a new one
no reply yet.
I know Dezod is one of the few stand out companies out there. I mean I have bought injectors and the PNP harness from them, with excellent prices and shipping.
In no way am I making this post to bad-mouth Dezod in any way! I'm just seeing if there are any suggestions out there that may help prior to needing to send it back. That little ounce of boost...oh man....I miss it already!!!
well good news I got it working thanks to a lot of research on the emanage and the dezod PNP harness. It should really not be this hard to get the info though so I will be doing a write-up for the emanage blue and dezod PNP harness
my06tc
06-25-2015 12:18 AM
clickclickw00t
02-18-2015 08:57 PM
TheTripleC
01-04-2015 06:46 PM
