07 tc reflash back to stock problem
** UPDATE: the production Dates May 2006 through April 2007 scion tc ecu will not be able to reflash back to stock map. learned it the hard way today. the dealership tried to reflash twice and failed. called up corporate toyota, the response was also negative. so the 07's are considered "2007MY" what ever that means. if you got the ecu reflashed, there is no way to go back, other than another ecu.
so i got the junkyard ecu, looks like the immobilizer thing is locked down or something, the car wont start up. obdii communication is there. but no start. which pins am i supposed to be jumping? please help im running on the trd flashed ecu to get by right now. im also fed up with the stealership taking my money again.
Follow this DIY, I can vouch that it does work. I've done it first hand on a friends car.
https://www.scionlife.com/forums/sho...5+minutes+safe
thanks to SMack and Garage of course.
cid_mcdp
01-05-2015 02:45 PM
fluxingnation
12-26-2014 04:28 PM
PTUNING
12-06-2014 03:58 PM
darkshadowofxdeath
12-03-2014 06:59 PM
