07 TRD S/C dyno (and vs stock)
seems to me I saw info awhile back that showed ( actual results ) where the stock bpv bled enough to have the peak boost a couple points below the "advertised" psi it should have been. So if that's the case, and we paid 3-4k for "X" amount of boost and we aren't getting it without changing the bpv......... there could be enough of an argument there in our favor if they tried to void warranty on that item alone......
just thinking out loud, that's all...
Originally Posted by kanundrum
Originally Posted by VitViper
It takes me like 30 minutes to swap the BPV, so I'm not even gonna bother arguing lol
did you remove the rubber piping?
Helps that it's not my first time touching a car... I'm the guy that swapped his motor/tranny in his ZX2 (with a fresh set that didn't have 140k miles on it) and installed a custom built turbo setup in under 2 days... all on my own in the carport by my house using jack stands, jacks and a cherry picker LOL
edit: me after a hard day of work http://fullavit.com/content/Pictures...wap/biotch.jpg
^^ at least you had a cherry picker... i once had to swap out a motor from my Camaro ( 70 1/2 ) using a winch and a large tree.... out in the grass..... yeah being a poor country boy sure had it's "perks"...
it had more room...... but there were still many "bombs" dropped and cans of beer swilled out in that wonderful summer heat. Sure made you learn every inch of a car though.
Now working on a pinto with the v8....... I can appreciate working in tight spaces
Originally Posted by Wyatt_Herb
REAL.
INFOR.
MATION.
Thank you so much.
Any comments on the AFR spike at 4100 rpms? The others looked nice but is the blue one safe?
Congrats. 40hp gain my ***.
INFOR.
MATION.
Thank you so much.
^^ i'm sure it's quite possible that many are fine; i just remembered seeing a sheet on here after someone's dyno run that showed boost a couple shy of advertised until they went with the 110. All it could have been was a line not tight enough, or maybe a faulty valve to begin with.
Scion0814
Scion xB 2nd-Gen Wheel & Tire
02-12-2015 01:41 AM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
darkshadowofxdeath
12-03-2014 06:59 PM
