1/8 NPT Fitting
Old 04-13-2010, 01:58 AM
tC_litigator's Avatar
as far as the oil fitting on the block, I know that Rob at Descendant sells one that is a direct fit for the tC block....one that dosen't cross thread. Give him a call!!
tC_litigator is offline
Old 04-13-2010, 05:31 AM
cavalierkid888's Avatar
Originally Posted by aen
or look for a local hose shop, any city/town should have at least one.
ask them for air hose npt fittings
they are all the same as long as htey are brass
I went to my local ace hardware and they didn't have a 1/8th bpt to npt adapter...
The kit I'm installing is actually the descendant kit...I wonder if that fitting comes with the kit....I guess I'll have to ask when I call them to order this weekend.
cavalierkid888 is offline
Old 04-13-2010, 04:26 PM
aen
aen's Avatar
unless you call a specialized shop people are ussually like what teh hell is a npt
what about home depot? in the air compressor isle
aen is offline
Old 04-13-2010, 05:09 PM
^^I'm gonna check after work today.
Old 04-13-2010, 05:30 PM
aen
aen's Avatar
dont' ask for specifics, people ussually don't know. just go look for that section
aen is offline
Old 04-13-2010, 11:40 PM
^^^Yeah that's what I did, and they def. don't have it.
Old 04-16-2010, 11:21 PM
That part threads into the block perfectly! I just threw it on and had some leakage, but some teflon tape will take care of that...
Old 04-16-2010, 11:54 PM
crush02342002's Avatar
where did you end up getting it at?
crush02342002 is offline
Old 04-17-2010, 12:30 AM
^^ the hyperlink that jamaican posted on the first page.
Old 04-17-2010, 12:40 AM
nice...think ill order a few to keep around if i cant find em cheaper els where
Old 04-17-2010, 02:33 AM
jamaican's Avatar
glad to hear it worked out for you. now we know what adapter to use and that it fits correctly.
jamaican is offline
Old 04-17-2010, 02:40 AM
jamaican's Avatar
if possible, can you take a pic of the of the connection to the block so everyone can get a visual?
jamaican is offline
Old 04-17-2010, 01:31 PM
ElevationTC's Avatar
Completely off topic. But Chris ur new engine bay > Old engine bay :O
ElevationTC is offline
Old 04-17-2010, 03:42 PM
Team Scionara
skinnayyy's Avatar
i don't know if it's my work computer or what but when i go to vguages.com it says account suspended.
skinnayyy is offline
Old 04-17-2010, 05:51 PM
jamaican's Avatar
Yea i just clicked on it and it says account suspended as well
Well here is another link i found: http://www.pegasusautoracing.com/gro...D=PLUMADAPTBSP
As long as you go to google and type in BSP to NPT adapter or fittings, a few places will show up.
But yea the block is BSP threaded so we need these in bulk for the boosted scionlife community.
jamaican is offline
Old 04-29-2010, 02:04 PM
asianorange's Avatar
For what it's worth I would like to contribute my experience and solution
After visiting skinnayy to see his install I saw his feed line was plumbed 1/8 NPT into the block.
Despite reading this thread I tried to fit 1/8 NPT but could only get in 1/3 a thread before it came back out with a sliver of aluminum from the block.
I ordered the NPT-> BSPT from JEGS ( http://www.jegs.com/i/Auto+Meter/105/2269/10002/-1 ) and the damn thing still didn't fit.
I had a close look at the stock pressure switch and compared to the existing NPT adapters I tried and the JEGS, the Stock pressure switch appears to have a slight conical taper at the threadbottom, the JEGS piece was dead straight
The solution: I threaded the JEGS through the back end of a 3/8 NPT die to take down the starting threads (it was either that or tap the block.) To my surprise the part threaded in perfectly! (not loose, not overly snug) Added some teflon paste and got my T-Fittings in. So far 50 miles no leaks, not that I expected any but it's always good to check.
asianorange is offline
Old 04-29-2010, 02:59 PM
jamaican's Avatar
good info. thanks for sharing asian. More people should post up their tips and recommendations so we all can gain from it.
jamaican is offline
Old 04-29-2010, 03:05 PM
jamaican's Avatar
so now we know if you are getting a BSP to NPT fitting, it has to be a tapered BSP male thread.
jamaican is offline
Old 04-30-2010, 10:54 PM
Woops! Totally forgot about this thread haha,
Well those two parts posted in this thread work together great as I stated.
So, this splitter- http://www.glowshiftdirect.com/1-8-n...g-adapter.aspx, which costs $18.53 shipped. Plus this adapter- http://www.vgauges.com/catalog/produ...8a4f293da45845 which costs $14.75 shipped will allow you to tap your block seamlessly.
The third "port" is currently plugged up, it's going to be for the oil return line when I install my kit in a couple weeks. That plug also comes with the splitter.
Also, I had to use teflon tape because at first it leaked a little, but now it's been on for over a week and I've done some heavy driving on it without a single drop of oil.
Old 05-01-2010, 01:18 AM
love the 4 way block!!!!
SpaceCaptain
05-11-2015 06:24 PM
KTamAK187
04-15-2015 10:08 PM
HotLavaDestiny
04-10-2015 05:10 PM
skruff
04-06-2015 06:34 PM
Quick Reply: 1/8 NPT Fitting
