+1 for another Turbo TC
Old 10-17-2008, 06:12 AM
GhostFaceKilla's Avatar
20 pounds? EEEEEKKK lol
GhostFaceKilla is offline
Old 10-17-2008, 07:59 AM
-HyphY-'s Avatar
20 lbs- wowz.
-HyphY- is offline
Old 10-17-2008, 10:36 AM
paulky_2000's Avatar
I run 10 lbs. every day...but I'm quite kind to my car!
paulky_2000 is offline
Old 10-17-2008, 10:39 AM
aen
aen's Avatar
it wasn't on purpose.
dumb friends and a trip to vegas don't mix.
aen is offline
Old 10-17-2008, 11:00 AM
TCpete's Avatar
cool so was mine
I have a piston that would scare you.
11.5PSI
again.. make sure timing is pulled at 12PSI.
You are running a stock motor out of a camry with cast pistons and a compression ratio of 10:1 with the carbon deposits
10:1 compression [/b]
9.6 on the 06 motors and 9.8 on the 07 motors.. add some carbon deposits and its like a 10:1 compression ratio. carbon = detonation. mix that with cast pistons and u have a ____ty turbo motor
TCpete is offline
Old 10-17-2008, 11:36 AM
Music City Scions
rhythmnsmoke's Avatar
cool so was mine
11.5PSI
actually the 06- models are 9.5 and the 07+ are 9.6
And I will add to that with a couple more
I guess we feel free to make up our own Compression ratios for our motor. LOL...bro, it's no where near 10:1 compression.
rhythmnsmoke is offline
Old 10-17-2008, 01:17 PM
purplenitroustc's Avatar
1. yes it is.
2. were still on cast pistons
purplenitroustc is offline
Old 10-17-2008, 01:36 PM
1UP Crew
RICANTC's Avatar
i guess those of us who see it in person when these engines go on and on boosted must be imagining things...
RICANTC is offline
Old 10-17-2008, 01:48 PM
CarbonXe's Avatar
To raise compression from 9.6 to 10.1, you'd need about .04" of carbon buildup in each cylinder. That's enough carbon buildup, that you'd be able to scratch it off with your finger nail. I have NEVER seen that much carbon build up in an engine before.
If this was true, engines would make more power as they get older. It's quite the contrary.
CarbonXe is offline
Old 10-17-2008, 01:53 PM
StreetStarsTc's Avatar
congratz on the turbo!
StreetStarsTc is offline
Old 10-17-2008, 01:56 PM
TCpete's Avatar
1. yes it is.
dude im sorry if this offends you... but your a freaking moron.
TCpete is offline
Old 10-17-2008, 02:31 PM
I guess
Cast pistons dont mix with F/I.. you cant have both and expect reliability without pulling timing
I have a chipped piston that shows 12PSI is too much for this motor without pulling timing. I was "tuned" also
I have a few turbos and a few motors so I have expierence with this car
Old 10-17-2008, 02:34 PM
the CR on the 2nd gen motors is 9.8
and there have been several revisions to the piston design
add carbon buildup for some hotspots and 12PSI is very dangerous over time
Old 10-17-2008, 02:53 PM
m6ar2cel6oTC's Avatar
i have added timing thoough out my whole power band and thats cause my s/c ecu keeping pulling timing from me so my tuner added timing to my s/c cu to make up from all the timing being pulled. but i still dont have any real real timing then my car needs or wants.
m6ar2cel6oTC is offline
Old 10-17-2008, 02:55 PM
Music City Scions
Yeah, ok bud we believe you.
Old 10-17-2008, 03:11 PM
My boost is set at 10PSI daily driven. No more arguing over it. The 12psi run was done because of a very sensitive MBC when we were trying to achieve 10 pounds
Old 10-17-2008, 03:21 PM
perfect. make sure 1-2 degrees of timing is pulled and im sure you wont have any trouble
Old 10-17-2008, 03:28 PM
KillaSmit's Avatar
<------ 16Lbs make my stock internals go bye bye
KillaSmit is offline
Old 10-17-2008, 03:47 PM
CarbonXe's Avatar
^ Good.
CarbonXe is offline
Old 10-17-2008, 04:30 PM
1UP Crew
ippskidder's Avatar
I've seen up to 14psi when I was tweaking my boost controller. I had set the AFR really rich in that area on my fuel map on the hydra as a precaution.
After that, I had it consistently at 10-12psi after the boost controller tweaks.
Yes, timing has to be pulled if your on boost, and have an appropriate AFR for the setup.
12psi is normal for high boost. Countless people run that and are fine.
Stock Sleeves are good for about what 400-450whp. That guy in puerto rico is making more than 450 on stock sleeves (CRAZY! lol)
Stock Pistons on premium gas about 350whp, and about 400whp w/ race gas.
#'s may vary, but these are on good tunes, with good setups, and standalones.
The way the car is driven is another factor, and how good the maintenance was obviously.
That amount of carbon build up that guy is talking about is ridiculous. I would be more worried about hot spots.
Water/Meth injection steam clean anyone? =)
ippskidder is offline
Quick Reply: +1 for another Turbo TC
