The 100 Dollar Manifold! PICS installed
It will crack eventually due to the heat. It's like how the DSM stock manifolds and turbine housings would crack over time. I would definitely get it coated as cast iron will soak up the heat and give it off fast. Stainless retains heat in the manifold a little bit better which helps with spool.
Good luck I hope everything works out for you this time.
are u saying to use a wg gasket? ive never used a wg gasket :o
how long is eventually
the propper way to do it is to buy a stage8 locking fastner set and do it the right way never have to worry about stripped bolts or loose bolts
http://www.stage8.com/
cant post a better link it being a flash driven site but go to performance automotive then imports then turbo kit figure out your thread on the mani match it up trusst me they are life savers i havent switched my scion to it yet but were a must on my old air cooled vw i havent had a stripped bolt or lose bolt on my entire kit i put together the turbo downpipe manifold wastegate with red lock tite let it sit for 2 days then installed it never had a bolt back out or go loose
