1000cc pnp injectors
P-Tuning pnp 900's
http://www.ptuningscion.com/subdir/i...l&ModelDesc=tC
best you'll get right now for pnp's
oh wow, hold the phone. Decendent sells 1000 RC injectors on their site with an RC-Factory harness
http://www.world-motorsports.com/wms...products_id=49
I stand corrected
I stand corrected
Injectors are classified into two categories.
1. High impedance/resistance (saturated) 12-16 Ohms.
2. Low impedance/resistance (peak & hold) 0.5-6 Ohms.
Saturated injectors require roughly 1-1.5 amps to open the injector. Peak & hold injectors initially needs about 4-6 amps, and once open drops to roughly 2-3 amps to keep it open.
ECU design will dictate the use of one or the other. Most late model cars will use saturated injectors.
for stock usage you would need saturated (aka high impedance)
here is an example of what you would need for peak and hold injectors
http://www.aempower.com/ViewCategory.aspx?CategoryID=83
some standalones have this feature built in such as the hydra
Re: 1000cc pnp injectors
Originally Posted by cburglb34
theres nothing u could have that would require 1000cc injectors if tis for running e85 just get 750 or 900 and runs a return fuel system with high fuel pressure
yeah most injectors above 700cc are low impendance which would damage our ecu.. you would need a standalone to use those..
but some makes custom high impendance like this one, oh its not really a complete pnp but it comes with a harness that plugs to the stock harness.. i think its better though coz they are easier to disconnect
http://www.fuelinjectorclinic.com/cg...ey=IS140-0900H
SloTC1
08-16-2018 02:45 PM
