-10an returnline helP!!!
I bought my oil feed and drain lines/fittings from Dezod, so it came with the correct bolt to use for the pan. I believe I tapped the pan with a 1/2" drill bit, which was slightly too small, so we just rotated the drill in the hole to widen it slightly.
According to Wikipedia, -10 AN is 5/8".
http://en.wikipedia.org/wiki/AN_fitting
Here is the only picture I have of the tap.
Make sure you put it high enough, so the oil can actually drain into the pan. Mine was positioned as high as possible, and I only had about 1mm of clearance between the pan lip and the fitment screw thing.
paul id love to buy your lines but i dont have time to wait for them....although i will be ordering them soon because comes saturday ill have ebay ones in my car...so in a week or two ill buy lines from u and some other goodies .....a 2.4 inch drop sounds good too
=] really...interesting i mean -3an would soo suit me well
The feed line kits are in stock, ready to ship. I have about 50 made up. How many do you need?
Oh yeah, Paul, thanks for the lines and help . I ended up having to cut a chunk off the return, because it was too long. Fits perfect now though :D.
paul i jsut ordered a feed, a return, and hardware =] please have shipped tomorrow
Return, depends on stainless or rubber. Stainless are in stock. Rubber not too sure.
Hardware, all set. In stock.
Shouldn't be an issue from what I see.
johnhawkins
03-28-2010 08:50 PM
