16g turbo
16g turbo
I recently built my engine and was wondering how much power could I possibly get out of this small turbo. My power goals are to have 350whp+ ...before building the engine I put down 300whp but now I have lower compression and the car feels a little slugish.
get a gt3076 I'm sure u can get 350+ easy on pump gas but i would go bigger like at gt35. Im sure u can get 350 at 16-18 psi but i think fuel will stop u unless u are using e-85,race fuel or water and meth to bring the octane levels up.
you guys are not helping this poor guy, OP you have a built motor trying to push 350hp, cool that is possible with a stock engine aswell but because the 16g is so small youll have 350 early in the power band then the power will just drop off, too small of a turbo it will blow hot air you will need a to4e or bigger for a good powerband
Dude when the hell does a fully built cylinder head give u less power. Also keep in mind I wrote high A/F on pump gas to get a true 350 whp every dyno is different. They can make it say 350 if they wanted to? I also think is EGT will be extremely hot but I think it's capable. I'm sure there a few evo's that have got 350 with cams and pump gas.
SloTC1
08-16-2018 02:45 PM
CrowJenkins
10-09-2015 10:47 PM
