17-18psi on stock engine...someone needs to explain this
Old 12-16-2006, 12:43 AM
DaGreat1's Avatar
Default 17-18psi on stock engine...someone needs to explain this
i was looking on youtube at videos, and this tC says "17-18psi on stock engine, 427whp"....here is the video.. http://www.youtube.com/watch?v=7a2egrK0SQQ ....does that sound little weird to anyone? and if so can someone explain
DaGreat1 is offline
Old 12-16-2006, 12:45 AM
mikescion's Avatar
look at the smoke coming out the exhaust after the dyno LOL doesn't look like it liked 17.5 psi on stock block
mikescion is offline
Old 12-16-2006, 12:47 AM
ProshopXB's Avatar
Oh no.... not SS again... This has been talked about and talked about.. Dont even mention the name of the company.. it is like saying the F word.. Forget you even saw it.. As Obi One would say to you.. "This is not the video you are looking for"
ProshopXB is offline
Old 12-16-2006, 12:48 AM
chrischoi's Avatar
scionspeed.com
chrischoi is offline
Old 12-16-2006, 12:49 AM
THansenite's Avatar
Originally Posted by chrischoi
scionspeed.com
*shudder*
That's the name....the bad word.
THansenite is offline
Old 12-16-2006, 12:58 AM
trdtcpr's Avatar
trdtcpr is offline
Old 12-16-2006, 01:10 AM
zer0's Avatar
Jamasco Race Engineering...
They were the orginal pioneers, but to bad they suck at business.
zer0 is offline
Old 12-16-2006, 01:36 AM
engifineer's Avatar
well, you could run 20 psi for a dyno run.. it wont last a day, but would probably survive a dyno run. As others said, bad company. Not to mention dyno queens are just that.. dyno queens.
engifineer is offline
Old 12-16-2006, 06:08 AM
g3kko's Avatar
The 103 octane race gas might have had something to do with it, as well. I would also be damn surprised if the ECU wasn't crapping its digital self and pulling like 15 degrees of timing. Which means that the same power might have been made with 14psi...
g3kko is offline
Old 12-16-2006, 06:13 AM
mattvs's Avatar
103 octane wouldn't help that car around the block unless it was powering the truck that was towing it.
mattvs is offline
Old 12-16-2006, 06:24 AM
g3kko's Avatar
Uh, I don't follow...
g3kko is offline
Old 12-16-2006, 06:31 AM
zer0's Avatar
well that 427whp, pulled a 12.03 1/4 mile, so it worked for more then a day.
zer0 is offline
Old 12-16-2006, 07:01 AM
Byta27's Avatar
i do have to admit that video is pretty sick i wish our engines could handle power like that with stock internals, im afraid to even turn it up to 10 i think even that would be pushing it on stock internals when im running about 8 now, i wonder what kind of internals u would need to be able to turn it up to that.
Byta27 is offline
Old 12-16-2006, 08:32 AM
bluesciontc's Avatar
i am runing 10 right now perfectly fine. Planing on pushing 15 soon stock internals why is every one afraid to turn the boost up?
bluesciontc is offline
Old 12-16-2006, 11:23 AM
OuterHeaven's Avatar
Well that 12.03 was done with less boost... I think 14 psi. They claimed that the head was lifting from the block at 17-18 psi so they lowered it right after that dyno run. Race gas plus tuning can go a long way plus being a shop car can definitely help.
OuterHeaven is offline
Old 12-16-2006, 05:15 PM
Music City Scions
rhythmnsmoke's Avatar
FYI....that car blew up naturally. Just like every other tC that was trying to push 17-18 PSI on a stock block.
rhythmnsmoke is offline
Old 12-16-2006, 05:24 PM
engifineer's Avatar
^^ he tells the truth
Like I said, you can surely do it and drive it for a short while, but a short while is about it unless you idle it around
Old 12-16-2006, 05:33 PM
drive in Vaccum. You can drive and get regular gas milage in VAC
Old 12-16-2006, 06:07 PM
DaGreat1's Avatar
well how much horsepower can the stock engine take, its not that boost that kills the enigne its the horsepower right???
DaGreat1 is offline
Old 12-16-2006, 06:21 PM
engifineer's Avatar
Well, its not the hp either, it is the tq if you get right down to it. The combustion process creates tq. HP is a calculation of how that tq is used.
But it can vary, depending on the failure. If you have horrendus blow by, head gasket failures, etc, then the boost is what caused it. If you destroy the internals due to force, then you could say the tq killed it (or the forces applying the tq). It is all semantics in the end though. The huge amount of boost created more tq (and in turn hp once related to rpm). so it is hard to say whether the boost or the tq killed it. In either case it died
Quick Reply: 17-18psi on stock engine...someone needs to explain this
