2008 Scion tC wiring diagram?
I'm looking to see if anyone has a wiring diagram for a 2008 scion tC?
I tried to hard wire my AEM FIC, and now I'm throwing seven codes and I would like to know where to rewire a few wires correctly.
If anyone would have any insight without me having to purchase a diagram..
The codes are:
P0010: Cam Shaft Position Actuator Bank 1 Circuit Malfunction
P0113: IAT Sensor 1 Circuit High Input
P0118: Engine Coolant Temp. Circuit High Input
P0123: TPS/Pedal Position Sensor High Input
P0335: Crank Shaft Position Sensor A Circuit Malfunction
P0453: Evap Emission System Pressure Sensor High Input
P2135: TPS/ Pedal Position Sensor/ Switch A/B Voltage Correlation
*The car does run fine when I have the car running off the ECU.
Just as soon as I start running off the FIC all of this begins to happen.
The codes are:
Used that to hardwire the fic.
Ended up having to put resistors on the cam and crank wires.
Problem solved!
Crush..do you create base maps?
Im still looking for a descent one.
Problem solved!
wwotr
03-28-2015 01:47 AM
