2008 turbo kits
Originally Posted by MrBurrito
the descendent turbo kits are the bomb make sure to check those out before you make your descision.
I am sorry man I have to argue with you on this there kits use cheap parts. Ptuning or Dezod FTW
Uses BPV instead of a BOV that could have been recirculated, No T-bolt clamps, Is the turbo Ball bearing they don't say, no stainless braded hoses used for feed or return. There were other reasons I would have to look at the kit again.
To the OP, the best advice really you can receive or get is to just take a look at the different kits offered, and DON'T take the word from the people here, including myself. We are all biased.....especially the manufacture of their own kits (of course they going to tell you to buy their kit).
Anyhow, take a look at the different kits (PTuning, Dezod, Turbonetics, World Racing, GReddy, TurboToyotas), and take a GREAT look in DETAIL at the components in the kits, the way they are constructed, do research on any pitfalls from the kits, should there be any. Take a look at the limitations of running a Log manifold vs EL (Equal length manifold). First you have to ask yourself....."At some point in my years, and I going to want to run more power". If you haven't been boosted before.....you will find out that boost is addictive. 250whp after so long will start to feel like stock, and you will want to know what 300whp feels like and etc..
So, do your research, those kits listed are the most prominent on the scene. Compare WHAT you are getting and for WHAT your getting it for.
ima have to mention Turbo Toyotas of course.... (i know trav you already mentioned it)
Originally Posted by crush02342002
you know after naming off some of thes companies i realized that we are a spoiled group to have all thes kits made available to us....
aftermarket support ftmfw!!!!!!!!!!!!
most other car owners would die to get the kinda support we have.
lookin into the ptuning kit. looks like hte best bang for the buck. considering it includes the aem fic, ill let the shop install it, crank it down to like 6-7 psi and tune it.
then i can hook up to the aem fic and play with it a bit since i hear the software is brainless to use
question, if i add either the greddy or apexi avc-r boost controllers, will i always have to adjust a/f when i crank the boost down or crank it up?
id much rather have a digitally controlled boost set up so i can easily go from drive mode to race mode.
ifigure it isnt a huge deal if i can hook into the fic but id rather not need a laptop every time i make boost changes
ive been playin with the AEM software this morning with some sample maps. like ive said before im considering buying the aem fic upgrade now for minor tuning for a couple horseys on the stock setup then re-map once the turbo kit is on
i wanna learn to tune my own car and ive been forum surfing between this forum and aem's forum trying to learn more.
think if i call p-tunning and have them take out the AEM FIC i can get a better deal? like i said, i wanna tune a bit stock and learn the differences in power and such, then once i got that down ill put the turbo kit on, let the shop tune it, and ill go back and fine tune it.
looking into it id rather get the upgraded modle that has the boost controller in it (and alls u need to do is buy the solenoid kit) and set up 2 maps, 1 for daily driving, and 1 for killing civics
edit: seeing as how the software has the option for tcs, should i enable it through the AEM fic sincce our tC's dont actually have TCS?
almost dont see the point cuz i warm the tires up with a little 2nd gear roll, slowly pull the brake back while giving it throttle. seems to spin both tires and get them warm. then i line up and take off. i figure the tcs would be good for take off but will suck to warm them up a bit.... i mean its not like i create a smokeshow.... often....
btw if i go with the p-tunnning kit with the garret t03/04e kit with the 625cc injectors, i plan on runnin at 7psi of boost for daily use and crank it up to 8.5 or 9psi to kill _____es.
since the turbo install will also involve lightened pullys and a new clutch, id rather do the fic first.
im an electrical guy anyway and im sure i can install it myself in a few hours with some crimps, soldier, and electrical tape.
i did install 80% of my own remote start
PTuning > all the rest.
I "guess" Honorable mention can go to Vulcan turbo, treadstone, and sound performance...
We do have a crap load of kit options.
Originally Posted by noskatana94
So I know everyone has there own opinion and such so here is mine. I am very supportive of everyone that has anything to do with making the Scion world better for all of us. But in the same sense I want quality and reliability and I want to know that it is proven, and with that being said I would 100% go with DEZOD's S1 Kit. For one what you are looking to do like a few other people have stated there is no sense in paying for more if you don't plan on using it. The S1 kit will come with everything you need to get you were you want, it was designed to be an entry level kit at a bargain price and it has been tested to the fullest extents. I have personally been running mine now for 2yrs and running on 8lbs and average 275whp and 255ft/lbs. This is my daily driver and I have had no major issues. Now just so you know I am not saying that the other kits are bad ones. Here is a link to the S1 kit and if you have and questions at all contact Paul at Dezod and he will be more than happy to answer any ?'s you may have. http://www.dezod.com/pd_force_fed_concepts.cfm
And here is a copy of my dyno sheet from when Paul tuned my car.
And here is a video of the kit in action. I know it says it is only on 7lbs but it is really on 8.
http://www.youtube.com/watch?v=6kC7vZ14LEg
ok....here we go.....ptuning will give you the absolute best bang for your buck!!!! and whats this turn boost down to 6-7??? oh please keep it simple 8psi is right where you need to be...if i were you i would be looking at 10psi but ..dont waiste money turning it down...8psi is reliable and powerful...please do the wise thing and get the ptuning kit and leave it at there setting at 8psi...done...and there kit looks the best
Everyones entitled to their opinion of what kit is the best to get but IMO why not just go with a Dezod s1 kit? Keep it on 8lbs of boost and call it a day. Correct me if I am wrong but it seems like they have one of the most bought kits on the market right now and the most R&D as well as many satisfied customers. Isnt the ptuning kit more than a dezod s1 kit? OP said he was looking for something simple granted his price range may be off...
And for 8lbs of boost, I am most definitely having fun with it. I have been in my friends Evos and STIs and although 264whp may not seem like much it pulls like a beast and I can honestly say I am very satisfied (well thats probably where the 290wtq comes in...)
Go to my sig for more info on my setup and see maybe if something similar to that will suit your needs.
PS. I still am going to up the boost eventually, but surprisingly enough right now it is extremely fun.
No, that's not accurate. Especially on being "most R&D'ed". Sure they have an abundant amount of kits out there....but you can see it also as being...."Do you want to be like everyone else, or do you want to be different?" That's just one aspect of looking at it as well. All the kits are good. And this is just my opinion, but the PTuning kit is "Technological Wise"...far superior than Dezods or TT's, let alone talking about it from a race stand point. PTuning's kit was first proven on a race track, then transcended down to the street. Everything else with the exception of World Racing started from the street and stayed there since they can make a quick buck by offering cheap kits. That's just my opinion, not bashing anyone or their kit choice.
And the sad truth of the matter is, SL'fers/Scion owners are cheap *****, so they want something for nothing. And catering to that said "cheapness" is taken advantage of by sticking with cheap kits/parts. Not to say they offer crappy quality parts or anything, just saying they are more in it for the money, so they want the most return on investment. Kinda like Walmart would offering a low price over a more upscale Target store (which are mostly found in more financially prominent areas).
todd on the other hand makes some really nice stuff. really really nice. the quality in his fabrication is incredible. i have not seen ptuning in person but i have seen dezod and turbonetics. i like the turbotoyotas stuff way better. it comes with a tubed manifold and not a log style. log style is more likely to create backpreasure witch is bad for your motor and you loose power. turbo toyotas offers quality parts at a good price. Customer service is good too. Todd has helped me out plenty with my build. He is a good guy and he is really into what he does. most of his kits make 270 whp +++ at 8 psi id say turbo toyotas all the way................
Update on Ptuning, they have a "tuner" kit with no fueling but if you need the injectors may wanna check with then for that. Just though I put that out there.... since it seems you have a AEM FIC already.
