2010 Full Dezod Alpha Series build... !!UPDATE!! NEW PIX
Thanx to you and paul for the sexy mani and everything else for my build.. Appreciate your guys work and insight.. Looks Fresh don't it. I'm thinking of making a small downlet off of the down pipe to run open DP.. love the way the tC's sound with the open DP.
not sure I understand. Well the tensioner is going to stay.. I'm going to run a smaller belt is most likely what i'm going to try and find.. If not i'm going to have to fab a flange and pulley system to make a belt fit.. *IF IT DON"T FIT MAKE IT FIT*
if you find a belt that fits, would you mind shooting me that part number??
The way the belt is run stock there is more involved than just removing the pulleys and getting a new belt. You either need to make a new tensioner or put an idler where the PS is.
Just giving you a heads up. Im working on this right now
That is correct. Custom bracket time with a pulley. Unless you can find a belt tensioner that will work.
As soon as i get everything and a clutch, fuel system, and wheels and tires.. or this thing ain't leaving the Driveway on it's own will.. Right now running on hopes and dreams.. but it's coming down to the wire..
